fuel relay questionmy86lxi 01-30-2002, 08:03 PM I have a 86 accord and here lataly it wont start every time, when I turn the key to on I can here the relay click and then the fuel pump humm and then the relay clicks again. but sometimes it dosnt humm and wont start, why isnt it humming? fritz_269 01-30-2002, 09:10 PM hmmmmmmmmmm.... ;) Quite probably your fuel pump is dying. They often go out in a slow and painful way. You need to get it checked out by a qualified mechanic. Good luck. :cool: my86lxi 01-30-2002, 09:17 PM I couldnt just get in the trunk and change it myselfe? I changed the head gasket, so hopefully I could change a fuel pump. Or do you mean there could be another problem fritz_269 01-31-2002, 03:50 PM Originally posted by my86lxi I couldnt just get in the trunk and change it myselfe? I changed the head gasket, so hopefully I could change a fuel pump. Or do you mean there could be another problem I mean there could be another problem. Could be the relay or the ECU or even the wiring harness. BTW, is the ECU throwing a code? I'm not sure how difficult it is to change your particular fuel pump - some of them are a real bitch - you might ask around in the accord forum. And it's always a little dangerous working with exposed gasoline like that. :cool: Automotive Network, Inc., Copyright ©2012
