Different Aux ? (cig lighter)dashesthroughdeath 07-19-2004, 05:55 AM can i just straight hook the cig input to the battery without having to worry about it burning out.......? and or should i put a fuse in the mix just incase ...... I got a 3 cig input adapter i'll probably just splice the wires to that , that way i dont have to rip nothing apart and maybe one day fix the original one. Your input is well appreciated. BTW I am new to this form just got this escort 92 model.......not the greatest vehicle in the world but it runs. chevyn0va1 07-19-2004, 06:00 AM can i just straight hook the cig input to the battery without having to worry about it burning out.......? and or should i put a fuse in the mix just incase ...... I got a 3 cig input adapter i'll probably just splice the wires to that , that way i dont have to rip nothing apart and maybe one day fix the original one. Your input is well appreciated. BTW I am new to this form just got this escort 92 model.......not the greatest vehicle in the world but it runs. :2cents: Im a real big believer in fuses if they blow there is a reason I would NOT bypass or go without one. I have seen cars catch on fire for the same reason. If you can handle spliceing wires im assuming you are comfortable enough to get a volt/ohm/current metere and checking voltages and for shorts. Thier must be a fuse for it you could get lucky and just replacing it may help but your right to start with basics of looking at connections and surfaces. (I had a car once where the plug needed to be cleaned oxidation was working against me)~alway start simple let us know. Automotive Network, Inc., Copyright ©2012
