Indicator Lightjersey crabber 07-19-2004, 02:04 AM Malfunction Indicator Light On. Checked For Loose Gas Cap And Put Gas In Truck. Service Said Ride For A Few Miles To Reset Same. It Did Reset And Camre Back On. Any Thoughts On Same. jg69s 07-19-2004, 11:00 AM Might be a bad gas cap the rubber seal worn/cracked prob it. BleedDodge 07-20-2004, 02:41 AM Since it reset, that's probably what the problem is and you lucked out... How do you know the light didn't come on for another reason? Did you check the codes? If it is indeed the gas cap giving you problems, that's what should be replaced... jersey crabber 07-20-2004, 04:41 AM Thanks for the response. I called the dealer and made a appointment to have it checked out. I'll get back to you when done. jersey crabber 07-21-2004, 11:16 AM Bad Output Sensor Automotive Network, Inc., Copyright ©2012
