S-10 Blazer hesitation when accelerating only.GARY BRUNGARD 07-18-2004, 10:35 PM Need help with s-10 blazer (91) I have done nearly everything to it as far as tuneing it up and replacing the computor still I have this hesitation when accelerating . Has anyone had this problem If so please help. :banghead: hotwheelsgt 07-19-2004, 03:25 AM its something with carb i think i have same problem if i get it fixed ill let you kno or if you get yours fixed let me kno. is it a 2.8L DBoss82 07-19-2004, 04:28 PM I own a '93 S-10 2WD. W in VIN code. I am having the same problems. I have replaced EVERYTHING. I don't have an answer for you. Welcome to my hell. hotwheelsgt 07-19-2004, 04:33 PM oh wait 91 has tbi mine carb. well mabe its the timing GARY BRUNGARD 07-19-2004, 06:38 PM Hey! I had the timming all checked out and still the same thing, yeah it's a 4.3 . I replaced so much crap I dont know what to do next. smokey041369 07-20-2004, 11:39 AM check 1.coil or coil pack 2. clogged injectors 3.fuel pump pressure 4.fuel filter 5.fuel lines 6.timing these are what normally cause hesitation when acceleration GARY BRUNGARD 07-20-2004, 11:29 PM I had the truck at a local garage and they did check the fuel pressure and return line wich checked out ok. The timming also is right on but I should check the injectors? GARY BRUNGARD 07-22-2004, 03:57 PM After changing the electronic spark controll module mounted on the fire wall and the pick up coil it finally fixed the problem. Now its victory beer time!!!!!! smokey041369 07-22-2004, 04:04 PM have one for me Automotive Network, Inc., Copyright ©2012
