OK guys this is for all tranny goroscooda069 07-18-2004, 12:28 AM My shifter was a bit sloopy so ipuuled it out while in nuetral. replaced bushings and reinstalled. Now the car only has 1,2 and nuetral position. in nuetral its reverse though and if its in 1 or 2 it wont even moved it just dies out. It wont go into 3,4,5, or reverse positions. HELP! :banghead: flex339 07-18-2004, 03:26 AM What did your shifter bushings look like when you replaced them? Mine were in pieces. you need to make sure you get all of the little pieces out. If a small chunk wedged itself in there it could be what's causing your problem. cooda069 07-19-2004, 09:46 AM there are no broken pieces. I believe i have a classic problem with the transmission forks bieng stuck somehow Automotive Network, Inc., Copyright ©2012
