Bliker problemcivicx_xracer 01-30-2002, 05:14 AM So check it out. I got a 93 civic ex and for some reason my left blinker decided to go all crazy on me:bloated: The hazards work fine, the right blinker works fine...but the left one blinks all fast like I have one of those hyper blinkers. What's up?:confused: Predator 01-30-2002, 09:52 AM Uhm sounds weird! Are the cables all ok?? Im not sure where the blinker is controlled by- if it is a relais [is this right] then there are probably two- one for each lamp, i would check this! praxis 01-30-2002, 11:00 AM Change your bulbs. (the most common cause) If this doesn't work...let us know and we can help you further. crxlvr 01-30-2002, 11:22 AM usually when one bulb blinks all fast, there is a problem in the line, either another bulb is out or the relay is messed up. Predator 01-30-2002, 12:38 PM Aah relay was the right name! civicx_xracer 01-30-2002, 05:05 PM Yeah, sorry I forgot to put some stuff. I changed all the bulbs so I know it's not that. As far as the relays that has to be what it is. I went into my fuse box and found the blinker relay but there is only 1. Is that right. I prolly just need a new relay since there is now way to tell if the relay is bad(short of doing an electrical test on it) I might just end up getting one of the hyper blinker relays from ebay cuz I kind of like it fast. It must bug people behind be:devil: Automotive Network, Inc., Copyright ©2012
