92 running hot
ekhunter
07-17-2004, 12:32 PM
I have just changed the thermo and flushed. What sould I do next. I have noticed that alot of people have problems with the overflow tank. why is this a problem. thanks for any help.
E
pctjk
08-22-2004, 10:35 AM
You may have the closed cooling system on your jeep. If so, you will need to change out the overflow tank cap. This cooling system is closed and the cap is a very important part of the system. Also did you change your thermostat with a aftermarket unit (Napa, Pepboys, Kragens) or a Dealer unit. The correct thermostat is a unit with a small hole in the unit. It is to be installed up. If you used another it will cause cooling problems.
Jeff
