motor mounts
1FASTCRX
01-30-2002, 04:48 AM
where's the cheapest place y'all have found to get b16 motor mounts for 91 rexes? Thanks :smoka: :smoka:
Kohhal
01-30-2002, 06:41 AM
Junkyards, I guess. Can't imagine you finding them cheaper anywhere else.
1FASTCRX
01-30-2002, 07:56 AM
So do you know of any how to's sites showing the use of used mounts in the install?:smoker2:
EightOhOne
01-30-2002, 03:19 PM
If youre using the stock mounts, youre gonna have to use the ones that come with the b16a or whatever your swapping in...but you have to weld them in which leaves a lot of room for error if youre not familliar with welding/engine swaps in the first place
everyone usually goes with aftermarket mounts
www.hasport.com they have lots of info on swaps and sell the mounts and linkage as well... talk to 13secondcivic in the 4th gen civic/rex forum for a cheaper price for those
also www.hcpengineering.com their kits come with 4 mounts, unlike hasport that has 3 in their kit...a little cheaper as well...the mounts+linkage can be had for around 410 from a guy on another board....
hcp sits the motor closer to the firewall....so theres more room up front for a turbo if you choose to go that route
soul180
01-30-2002, 04:36 PM
hye, i just bought a 92 integra ls engine for my 95 civic coupe, do i need engine mounts or will the ones for my civic work?
EightOhOne
01-30-2002, 11:15 PM
im not up to par on the fifth gen civics...maybe someone else can answer that...but i THINK you dont need aftermarket mounts...just use either the teg ls engine mounts, or the stock ones..not sure though...
you might wanna check your laws about putting an older engine in your car though...there are a lot of laws stating the engine must be at least the same age of the car, or newer..but if you have a hookup or something dont worry about it just a heads up
peace
Phatwhippin_CRX
02-01-2002, 12:31 PM
Your B18 will bolt right in...... the 5gen civic has the same chassis as the teg...
www.phatwhippinCRX.20m.com I've got a B16a install guide.....
soul180
02-01-2002, 01:37 PM
so i won't need motor mounts?
Phatwhippin_CRX
02-05-2002, 12:39 AM
Nope :) .......... I'm 99.9999% sure ;)
90CRXZCSi
02-05-2002, 01:29 AM
Yea, if your car is a 95, try to get a 95+ LS motor(B18B1) instead of the B18A1 from the 90-93. This will help you out with the laws and emissions better because the motor is the same age of the car.;)
5_LiTeR_EaTeR
02-15-2002, 12:17 AM
YOU BETTER HURRY TO GET THEM MOUNTS! I got mine for 210 shipped. they use the left and right mount and stock rear mounted moved over. they also make solid rear mounts but theycause too much vibration... Oh yeah~~~~~~> www.engines-transmissions.com
soul180
02-15-2002, 03:37 AM
5_LiTeR_EaTeR, who/what are you talking to/about?
5_LiTeR_EaTeR
02-15-2002, 11:56 PM
www.engines-transmissions.com sells motor mounts and all the esstentials to do almost practical swap. They have having a 1 month special or something. check the site out... I forget their number should be on the site. It was for the b16 in the rex. I just finished my swap of a b16a in my rex and you won't need mounts for your swap soul180.
