Hyde's New DynoJekylandHyde 07-17-2004, 12:28 AM I redynoed Hyde today. The only changes on Hyde since last year's tune were the addition of a Walbro fuel pump and a Ross Machine Racing Manifold. I know Tom @ Ross and everyone else on here is going to be super excited to see these results since the only real change was just the manifold. I want to thank Eric and Benny at World Motorsports (Chris Rado's Shop ~ they were awesome to deal with!) Manifold is here: http://www.rossmachineracing.com/mr2intake.html (search show-n-shine" for my threads with the powder coated pics) Last year: Street tune (29 psi FP): 15 psi (boost) = 258 rwhp This year: Street tune (30 psi FP): 15 psi (boost) = 302 rwhp This year: Race tune (40 psi FP): 15 psi (boost) = 312 rwhp (race tune is a bit more aggressive) Your eyes are not deceiving you, the manifold made 44 RWHP on a 198,000 mile engine! I do not believe any other manifold has done that. Here's the kicker. I had a boost leak AND we did not really "tune" the car. We actually used the "tune" NoShoes gave me, but I upped the FP 1 psi. BIG BOOST Last year: Race tune (35 psi FP): 20 psi (boost) = 308 rwhp This year: Race tune (40 psi FP): 20 psi (boost) = 344 rwhp This year: Race tune (40 psi FP): 22 psi (boost) = 351 rwhp The lack of big increase from 20 psi to 22 psi is most likely due to the boost leak. Again this was with a boost leak and we did not make any adjustments on the SAFC or the VPC from last year (lack of time). There is absolutely more power to be made with the car the way it sits. Torque actually stayed about the same and I did lose some low- and mid-range power. You will note on the dynos that in the mid-range it got pretty "fat" (rich) ... so there is more power to be tuned in there, we just did not have the time to look for it today. I went for a very short ride @ 20 psi after the dyno and I managed to miss every gear! ... the car screams to redline now. Notice no drop off on the graphs, it just keeps climbing. I am going to have to alter my shifting habits to get used to this. My 235 street tires had zero traction for all of 1st on a heatlhy launch ... :headbang 351 RWHP video (notice the water injection spraying out before the TB, that is where the leak is): http://www.jekylhyderacing.com/images/hyde_351_dyno.mpg 15 psi & 20 psi dyno: http://www.jekylhyderacing.com/images/hyde_dyno_15_20.gif 22 psi dyno: http://www.jekylhyderacing.com/images/hyde_dyno_351.gif Old 15 psi and 20 psi dyno: http://www.jekylhyderacing.com/images/hyde_dyno.jpg drazhartd 07-17-2004, 01:32 AM hmm. Are these manifolds mass produced, can we buy one for ourselves? And congrats on the impressive specs. ac427cpe 07-17-2004, 01:37 AM *passes out* that is awesome! btw, i still want to race :D Layla's Keeper 07-17-2004, 01:59 AM Dayum. Um, can Layla borrow one of those engines until I have enough for that Rover 3.5L V8? JekylandHyde 07-17-2004, 07:11 AM Are these manifolds mass produced, can we buy one for ourselves? These are custom pieces that are made-to-order. I linked to the manufacturer in my initial post. 200SXGTi-R 07-18-2004, 11:52 AM now jeff.. i remember you said you converted the AFM to speed density,... what does that entail? what is the exact function of a VPC?...i am vaguely familiar with this. Is The S-AFC all the tuning device? so you basically just took the numbers that "no Shoes" gave you and set them? i like that manifold too. What about the TVIS? do you still have this ? what is its purpose? does the JDm engine gen III have this as well? JekylandHyde 07-18-2004, 12:11 PM The VPC makes the car speed density. By installing it, you can (and should) remove the AFM. For tuning I am using the VPC, SAFC and an adjustable fuel pressure regulator. I went with the same SAFC and VPC numbers "NoShoes" gave me before, BUT we added more fuel pressure to account for the extra air that the manifold offered. There is a bunch more power in this set up if we actually tuned the numbers more. The manifold eliminates the TVIS completely. It also elilminates the cold start injector and the entire EGR system ;) The TVIS closes 1/2 of your intake valves at low rpm to give the engine more torque ... as soon as you start rolling it opens up both valves. I will not miss it. 200SXGTi-R 07-18-2004, 12:24 PM can i just eliminate the TVIS and EGR JekylandHyde 07-18-2004, 01:37 PM Sure ... there are EGR block off plates that you can buy and there there is a way to disable the TVIS; however, the parts of it will still be "in the way" of the air stream. You can take the TVIS out of the intake manifold and fill the holes. drazhartd 07-18-2004, 02:40 PM The manifold eliminates the TVIS completely. It also elilminates the cold start injector and the entire EGR system ;) ... is there anything bad about doing this? TRD2000 07-18-2004, 03:39 PM i guess they put it there for a reason... meant to help with low end... fuel economy bla bla bla that sort of thing plus i think it helps when engine is cold... when you're running though it does nothing! that is one UGLY manifold my friend... one very ugly and very effective peice of equipment! I want one! JUN also make one but at like 20 times the price! So you really just changed the manifold and the fuel pressure? or was the first tune just the manifold with the previous fuel pressure? youngvr4 07-18-2004, 04:16 PM those are some nice numbers jeckyle JekylandHyde 07-18-2004, 09:10 PM drazhartd, TVIS gives you a little extra low end torque, the EGR is for emmissions and the cold start helps when starting the engine in cold weather. TRD2000, to each their own :) I love the way the manifold looks and regardless, I'll take funciton over form. As for your tuning question, I am not sure what you mean by "first tune"?? I tuned the car last year with what I had and sicne then I only added this manifold and upped the fuel pressure. youngvr4 , thanks man ;) drazhartd 07-18-2004, 09:54 PM drazhartd, TVIS gives you a little extra low end torque, the EGR is for emmissions and the cold start helps when starting the engine in cold weather. hmm... I hope it would still be possible to start in the cold without TOO much hassle... then again, I live in AZ. pro_am 07-20-2004, 05:20 AM Those numbers are sick! Congratulations. Should be able to get some kills on the street with that thing. Jake JekylandHyde 07-20-2004, 06:38 AM drazhartd, Hyde is not going to be driven over the winter :) pro_am, I could get lots of kills on the street, but I neer street race. Those days are long gone for me. 200SXGTi-R 07-20-2004, 09:39 AM what did you run when u used to street race ? JekylandHyde 07-20-2004, 09:55 AM I'm not sure what you are asking? ... are you asking what kind of a car did I run or what kind of times? I've only owned MR2s and beater-hatchbacks. I have raced all of turbo MR2s in the past. 200SXGTi-R 07-20-2004, 11:30 AM what setups were running on the street? and what time were u running when you timed the car at the track? what were some of the biggest upsets on the streets? where did u run? were you the fastest? did everyone call you out to run to prove themselves? i have done the whole street racing thing out here in NYC a 200sx with motor swap and i was respected in some circles i eventualy timed the car when not in top form in the 12's. my biggest kill was a viper from a roll. mind you i timed the car @ 15psi with no traction and got 12's but when i ran the viper i was leaner and running @ 20psi! from a roll. i blew up at over 150mph and then he passed me but i was happy. JekylandHyde 07-20-2004, 11:35 AM I never was involved in organized SR. It was only the random red light meetings or highway sprints. My turbo MR2s where in the high 12 to low 13 range when I raced. I had no reputation at the time. I have a lot of people that want to run me now though :D I never had a chance to race anything special ... usually just the misguided, weak-egoed vetter and mustang drivers. MR2Driver 07-20-2004, 03:46 PM Im pretty sure if we were on a pass that was used as a hill climb i could bully you into pushing Hyde a lil bit, just to flex those skills Jeff... JekylandHyde 07-20-2004, 03:51 PM I did not say that I never push Hyde on the street. I said I do not street race. There is a big difference. :) TRD2000 07-20-2004, 03:56 PM despite the attraction.... have to agree, over street racing. was still fun making a dick of a guy in a mustang cobra last night. 200SXGTi-R 07-20-2004, 10:01 PM lol i used to live for it...ive been doing that since age 15. i don't do it anymore but i do push it a little when some one pulls up on the highway or redlight every now and then. Since i got locked up for it and had my car taken i have toned it down to almost never. TRD2000 07-20-2004, 10:41 PM I Think I'm Lucky To Have Gotten Over It Alive, Unhurt, And Un-caught. Tach_it 07-21-2004, 06:12 AM Mr Jekyl those are very impressive numbers that makes me want to own a MR2, your information is very valuable, especially when I trying to decide on my next car, by the way are'nt you afraid that all that power will find a weak spot on that old engine?!? JekylandHyde 07-21-2004, 06:20 AM Tach_it, I fully expected to blow up my engine on the first 1/4 mile run I ever did with it ... 3 years later I have over 90 passes on it. If it blows up, it blows up. I do not rely on this car for transportation. It is purely a recreational vehicle. 200SXGTi-R 07-21-2004, 08:28 AM thats the spirit! thats the way i feel even though its my only means of trans.... TRD2000 07-21-2004, 04:21 PM he's still within the reliable power limits for a stock 3sg Tach. These engines are nuts. Tach_it 07-21-2004, 07:45 PM more power to ya, and Hyde ;) Automotive Network, Inc., Copyright ©2012
