K&N Filter without Pop Charger
Google
Web AF
Dprotech
05-21-2001, 09:52 AM
Someone asked me how I had my K&N Filter put on. Well it was simple ..the box filter was removed and an adapter was put in that fitted a K&N Filter. I think a picture will speak a thousand words here ..take a look
poppy_morenito
05-21-2001, 10:55 AM
I don't see the picture ....
DVSNCYNIKL
05-21-2001, 11:11 AM
Hmmm, that pic would make it worth while.
Dprotech
05-22-2001, 12:59 AM
Here are the pics ..sorry probs with my firewall
Dprotech
This is how it is mounted ..to the chassis
Dprotech
05-22-2001, 01:01 AM
a Closer look at the fit ....
I've since removed the filter box ..but can't figure out what to do with the sensor in the original intake front end. Doesn't seem to affect performance .....I just cleaned the filter ..car feels better now.
dchien
05-24-2001, 02:43 PM
dpro... have you noticed any difference in performance?
it looks easy to put in yourself....do you think it is?
why did you keep the bottom half of the filter box on?
thanks in advance
d
DVSNCYNIKL
05-24-2001, 03:11 PM
That's a very good job.
Dprotech
05-24-2001, 03:47 PM
I removed the bottom box this week while cleaning out the filter. I left it on to check the performance and to make sure that the attachment was strong enough.
Without the box ..there is a ton of room for air to flow in.
Performance is night and day ..car is much more responsive in the upper range. without an exhaust you can feel the engine straining against the back pressure. Once this is relieved ..its free power all the way to redline.
thanks dvs
Dprotech
05-24-2001, 03:49 PM
the adapter can be obtained as a part for the sr20de engine. And yes it is easy to put on. You will have to fabricate the attachment bracket
poppy_morenito
05-25-2001, 02:55 PM
thanks dvs
Did you remove the bottom with just a screw driver ?
I have an intake they left the bottom on mine, I thought it defeated the purpose having the cylinder shaped air filter to have hal of it covered ....
GTO-TT/Chev57
05-25-2001, 03:56 PM
When you change to this type of filter make sure you don't get to much engine heat in there. Cold air going into the filter is just as important as flow. I have seen people make a cover over them and a pipe so cold air from the front of the car is sucked in and this makes a big difference.
Google
Web AF
