caravan start
nfmccann
07-16-2004, 01:21 PM
97 Caravan has intermittent start. Turn ignition switch and only get a "click" and sounds of a weak battery. Strong headlights and regular indications though of all electrical components. Replaced battery as a good place to begin. Cycling of ignition switch seems to eventually get a good strong rotation and subsequent start...
Have read many threads of ignition switch failing or starter solonoid contacts failing or even posible loose wiring/short around the starter...has anyone narrowed this down further???
:banghead:
capoeta
07-16-2004, 02:24 PM
have you had your started tested?
cj99
07-16-2004, 06:48 PM
I agree. Had the same problem with my 97. Had starter changed and good as new.
nfmccann
07-17-2004, 03:19 PM
The mechanic that replaced the battery says he checked it and it was "ok". In other words he was not able to duplicate the problem. I am about to change the plunger and contacts for a $20 shot in the dark...will that be enough or should I replace the whole starter for $120+??? Thanks for the reply.
janandkyle
07-17-2004, 07:29 PM
cant you have the starter rebuilt? i had mine rebuilt
for our '91 and it only cost $40.00
still working after about a year
