My engine suddenly lost half of it's power!
Rusty21
07-15-2004, 06:41 PM
I have a 1988 Mazda R-X7 GXL (non-turbo). 13B for a motor. I was driving down the road one day, and the motor suddenly lost probably half of it's power. There was not any noises when it happened. The oil pressure is still normal, and the engine temp is still normal. The car will start, if I hold the gas to the floor. However it will not run on it's own unless I am holding the gas. (Less than half throttle). And it will not rev higher thean 6 thousand rpm. If anybody can give me any good advise, it would be greatly apprieciated.
J-Rat
07-16-2004, 01:42 AM
A compression test would be the first thing I would try. Sounds like you MIGHT have lost an apex seal.
ShortyDTP
07-16-2004, 02:09 AM
check you injectors plugs. and injectors .
compresion test too .
Soyo
07-16-2004, 03:10 AM
thats about all you can do at this point, then get back to us
Eurotuner325i
07-16-2004, 11:27 PM
possibly a clogged up cat? idk just a guess
Soyo
07-17-2004, 03:54 AM
yea your rotor probably got disconected, went down the header, and got stuck in your cat :screwy:
SOIA
07-17-2004, 04:45 AM
I vote apex seal
RRRRRRRRRRRRRRex7
07-17-2004, 12:38 PM
what does the AF read?
Rusty21
07-27-2004, 08:47 AM
I performed a compression test according to the Haynes repair manual. The upper front spark plug hole had a good reading. But the upper back spark plug hole had nothing. (compression guage did not have any reading on rear upper hole). What does this mean????
D3rELiC
07-27-2004, 12:03 PM
you've just blow your engine ! congradulation!
i have one for sale if u are interrested, pm me
RotorBalls
07-27-2004, 03:28 PM
yikes, typical rear rotor went bye bye. Time for a rebuild buddy. :( I've been trying to get my rebuilt engine re-rebuilt all summer. Fucker only got 900 mile before taking out a couple apexes
ls1mazda93rx7
12-11-2004, 05:16 AM
put Ls-1 in it, hand down better than the ford 4.6
mcs
12-11-2004, 07:06 AM
whats with you and ls1 swapping?
ShortyDTP
12-13-2004, 03:06 AM
"*put an LS1 bla bla bla *" ...............FUCK THAT !!!!!!
mcs
12-13-2004, 08:28 AM
werd!!!
drftk1d
12-13-2004, 07:26 PM
no, put an ls1 in it.
so i can slit your throat!
