Power is on after keys are removed
honda2man76
07-15-2004, 10:30 AM
I have a problem. Yesterday, I noticed that after I turn off and remove the keys from my 94 accord, the lights on the A/C panel in the car was still on. I also tried to open the windows and the sunroof. Both open with out the key in the ignition. They never open unless i turn the ignition on. However, no light on the dash remain on. It seems the ignition is still on after key is remove. Probably the accessory wire , somehow power is left on to that wire. Has anyone had this problem. Could be a malifunctioning relay? I disconnected the battery, because i don't want to drain the it. Please help. Is possible that it is a short some where in the wiring.
I need help..
Thanks
WalkMan5
07-15-2004, 02:07 PM
ok that is what happens with the car once you open your door it will cut the power to everything. there is nothing to worry about its normal.
honda2man76
07-19-2004, 09:42 AM
Thanks WalkMan5... I also had a malifunctioning relay. I have a relay that is hookup up to the accessory wire. Fix the problem. Thanks again
