Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 07-14-2004, 11:38 PM   #1
blazerBR
blazerBR Normal reputation
Dome light won't turn off
The dome light in my 92 Blazer won't turn off. It's not the switch on the dash. Any suggestions?
blazerBR is offline   Reply With Quote
Old 07-14-2004, 11:53 PM   #2
burnM
burnM's Avatar
burnM Normal reputation
Re: Dome light won't turn off
Check the switch/plunger in the door hinge area. It could be broken in there....
1991 9C1 Caprice - daily driver
1977 GMC Jimmy - daily driver
1995 9C1 Caprice - new money pit
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
burnM is offline   Reply With Quote
Old 07-15-2004, 04:42 AM   #3
Strate
Strate Normal reputation
Pull the fuse that will turn it off.
K&N FIPK Air Intake, Gibson Exhaust
2 Neon UB's Kits, 2 LED UB's Kits
Surround Sound, Custom Front End
Clear Corners,
Custom LED Brake Lights Being Made
Strate is offline   Reply With Quote
Old 07-15-2004, 02:02 PM   #4
tomminajar
tomminajar's Avatar
tomminajar Normal reputation
Pull the bulb - Or check all the door switches - Ps it stays on for about a minute after you shut the door. That's an easier fix that even the light bulb :P
tomminajar is offline   Reply With Quote
Old 08-06-2004, 05:29 PM   #5
Dust2k
Dust2k Normal reputation
This is a problem with your door switch.
Its actually a common problem, and its why the blazers have that stupid 'dome light override' switch... come on, seriously, GM you need to fix your vehicles, not just mask the problems.
Pull each door switch out in turn with all other doors closed, and wiggle them around Eventually when you find the right one, the problem will go away.
Also, there should be some codes on the computer as well if you have a theft lock II (it reports the codes back for whatever reason). Strange I know, but its what happens. Rain / washing the car, can cause it, or it can just happen on its own as well.
Dust2k is offline   Reply With Quote
Bookmarks
Google
Web AF
