95 Odyiceman2 07-14-2004, 11:20 AM I have a 95 Odyssey, best car I've ever owned in terms of reliability, 200k miles, no problems, I want to sell it, but the ABS and SRS warning lights are on and I need to get these fixed, Honda wants $2k, please help, thanks. lorunner 07-18-2004, 12:12 PM The pump/modulator usually leaks on them. check the resevoir on the ABS unit if its empty you can fill it up and clear the code it should last a while untill its empty again. Thats assuming its a code 1. iceman2 07-18-2004, 12:31 PM Yes, I think it is the codes on the SRS and the ABS, how can I clear them? The SRS started when I pulled the fuse out while the van was running. BTW, you're probably right about the recall, I ate $400. lorunner 07-18-2004, 12:38 PM If im not mistake by pulling out the Hazard fuse from the under hood fuse box for 10 seconds it should clear the ABS code iceman2 07-18-2004, 03:22 PM Thanks, I'll try that, should the ignition be on or off? Also, is there a similar procedure for the SRS? lorunner 07-18-2004, 03:24 PM ignition should be off. The SRS is more complicated. I'll see if i can find the procedure to post it. iceman2 07-19-2004, 09:50 AM Lo, tried removing the hazaed fuse, is this the little 10 amp deal under the hood? The ABS light still comes on lorunner 07-19-2004, 04:39 PM did you fill the ABS resevoir full with fluid? iceman2 07-19-2004, 09:09 PM I will try, thanks. iceman2 07-20-2004, 10:42 AM Lo, there are several tech bulletins relating to the SRS and ABS put out by the NHTSA, do you know how I can get my hands on them? Automotive Network, Inc., Copyright ©2012
