my sl is now on three cyclendersadragon202 07-13-2004, 01:04 AM maybe some one can help me i have a 95 saturn sl with a 1.9 engine about two to three days ago i lost a cyclinder. it's the number 1 cyclinder. i have tryed to replace the wire, plug, and coil to no help.so im lost can some one please help thank you sierrap615 07-13-2004, 01:58 AM before i start my long list of questions, let me just say if those are platium plugs, thats the problem. is changeing the coils, wires plug the only things you have done? how did you conclude it was the number 1 cylinder? any blow-by or SES light? are you sure you are getting fuel? i dirty and unsafe test is to disable the DIS(pull the fuse), and pull out just the one spark plug. DO THIS OUTSIDE NOT IN A GARAGE!! crank the engine a few seconds, no more, it shouldn't start, but if it does kill the engine fast. you should be able to smell the raw fuel thru the spark plug hole. you can test the DIS coils by disconnecting the spark plug wires and have a second person crank the engine, you should be able to see the spark jump from tower to tower. if you have spark and fuel, then thats leading more to bad valves, but thats alot harder. is that the SOHC or DOHC?, how many miles, and how much oil does it burn. adragon202 07-13-2004, 06:40 PM how i know is because i took the plug wire off and it didn't change a thing. no i'm not using platium plugs. if i remember right the one plug was cover in oil or blow by. thanks for your help any more help would be nice thank you adragon202 07-13-2004, 06:41 PM i forgot something the motor still runs adragon202 07-14-2004, 12:39 AM its a sohc.ut has about 200k and 1 qt about 350+ miles sierrap615 07-14-2004, 03:19 AM heres the thing about the DIS, it called a waste-spark system. it fire two spark plugs at once(in this case 1 & 4 and 2 & 3 fire together). other systems jumps the spark from the coil thru the spark plug to ground, the waste spark system jumps the spark from the coil, to one spark plug, thru the cylinder head to the other spark plug and back to the coil. confused yet? so basicly if you pull the wire off number one it will kill number four too. so i'm not sure if just pulling off the wire proves its number one. anyway. first double check the coil leading to 1 and 4 like i said above by checking for a spark tower to tower. and clean that plug. 1 qt every 350 and the fouled plug lead me to beleave MASSIVE blow-by. the oil fouled plug maybe the problem. or the blowby is so bad the intake air/fuel is going past the rings, instead of compressing. sometimes a "MMO soak" will clean up the piston rings. look over at saturnfans.com in the how-to section, it was posted my Wolfman. after that, a steam cleaning may help also, but i wouldn't steam clean with a dead cylinder oh yeah, any SES light? adragon202 07-14-2004, 12:10 PM do you guys think rebuilding the cyclinder head would work? the good thing and bad think about this car is i bought the ar cheep and the bad is i dont have alot of cash now adragon202 07-14-2004, 12:13 PM if you mean the check engin light yes but when it happends the engine rev up and back down.thank you for your help. sierrap615 07-14-2004, 01:01 PM are you saying the engine revs up and down by itself?is the SES ever consently on long enough so you can pull the code? rebuilding anything is a long way away. to start, do the MMO soak. it also sounds like your intake is gunked up, so spray some intake cleaner into the throddle body. check your PCV valve(don't use any PCV valve except the one from saturn), take the EGR off and clean it to, you should get a new gasket, but if you can't, the old one may still work, decide for yourself. also, if you never have before, replace the ECT, its a $15 piece that will pay for itself in gas mileage. the old nylon ECT were crap, replace it with the new brass ECT adragon202 07-14-2004, 09:37 PM yes the check engine light comes on so i should have a code in the computer. what is the ect? adragon202 07-14-2004, 09:46 PM i think i'll try the mmo soak, i put and new throddle body on sierrap615 07-14-2004, 11:53 PM ECT = electronic coolent temp sensor you don't need a new throddle body, just clean it out. i don't know if you'll be able to pull the codes or not. but heres how, do this with key on engine off. under the dash, by the hood poper, there is a termial, 2 high, 14 or 16 wide i think. there will be only three wires hooked up to it. all on the right side, two on top one on bottom. with the engine off, put the paper clip in the two top holes, shorting it out. the SES light will blink the codes. IE one blink, pause, two blinks, pause is 12 three blinks, pause, six blinks, pause is 36 each code is repeated three times, then it goes to the next code, once all codes are read, it goes back to the first and repeats. the first code is always 12, its "Diagnostic System Check" the codes are: Diagnostic Codes 11. Transaxle Codes present 12. Diagnostic System Check 13. Oxygen sensor, circuit open or not ready 14. CTS circuit, out of range high 15. CTS circuit, out of range low 17. PCM fault, pullup resistor 19. 6x signal fault, no 6x signal between reference pulses 21. TPS circuit, out of range high 22. TPS circuit, out of range low 23. ATS circuit, out range low 24. VSS circuit, no signal 25. ATS circuit, out or range high 26. Quad Driver output fault 32. EGR system fault 33. MAP sensor circuit, out of range high 34. MAP sensor circuit, out of range low 35. IAC valve, rpm out of range 41A EST circuit open 41B EST circuit shorted 42A Bypass circuit grounded 42B Bypass circuit open 42C Bypass circuit shorted 41. EST bypass, open or shorted 42. EST bypass, open or shorted 43. ECS (knock sensor) circuit open or shorted 44. Oxygen sensor indicates system lean 45. Oxygen sensor indicates system rich 46. Power steering pressure switch circuit, open 49. Idle rpm out of limit high (vacuum leak) 51. PCM memory error 55. A/D converter error in PCM 81. ABS message fault (1993 vehicles with TCS) 82 PCM internal communication fault Diagnostic Flags 27. Quick quad driver output fault (1993 only) 48. Reference imput intermittent or noisy 52. Battery voltage out of range 53. ESC knock present 54. Five volt reference ground 58. Battery voltage unstable 61. 6x signal fault 63. Option check sum error 67. Handwheel sensor circuit fault 71. Cooling system temperature high 72. Coolinng system temeprature low 73. CTS sensor unstable 74. CTS/transaxle temperatuer sensor ratio error 76. ATS sensor unstable 83. Low coolant (1993 only) adragon202 07-15-2004, 09:15 PM im going to try this stuff tomarrow i'll tell you what happends adragon202 07-16-2004, 10:48 PM heres what i have done up to this point. i have no codes in the ecm, the new pcv doesn't work. im tring the mmo right now it will be done in the morning. so other than what you said already any other ideas? thanks again bobenhotep 07-17-2004, 02:55 PM hook a vacuum gauge to it. if it flutters it is probably a burnt valve.you may also have a hole in a piston. it will lose vacuum on the intake stroke of the damaged cylinder. my sl1 did this a long time ago. if your vacuum reading is relatively flat, then you have a fuel or ignition problem. it does not sound like an ignition problem. if it is an ignition prob, it will move if you swap your plug wires... adragon202 07-19-2004, 08:22 AM no dice the mmo may help but it didn't help this problem.i'll try hooking up a guage. adragon202 07-23-2004, 03:56 PM so far nothing has worked i'm about too give up.the good news is the temp is back to normal.so this is what i tryed to date. i put in a new pcv,the mmo,new spark plugs,wires,a vac gage,cross the towers on the coils,took a look at the vavle train.when i did that i found 5 or 6 loose rockers.if any one has any other ideas please help adragon202 07-23-2004, 03:57 PM i forget too add a new thermostate sierrap615 07-24-2004, 01:38 AM have you had a lot of ticking valve noises lately? hate to say it but it's sounding more and more like your valvetrain is crapping out. did you mean there was to much lifter to rocker clearance? were they on the intake or exhaust side? adragon202 07-24-2004, 02:19 AM yes there is ticking noises but only a high rpm. both sides of the valvetrain intake and exhaust.i didnt check how much clearance adragon202 07-24-2004, 02:25 AM if the valve train is going i have one other question. would a dohc heads fit this block? and what eles would i have too change? sierrap615 07-24-2004, 02:28 AM and you said the vacuum gauge read steady right? you said its been burning oil, did you ever let it get to low? how did those old spark plugs look? all the same or different. ever hear of a cylinder leak down test? adragon202 07-24-2004, 02:35 AM the vac guage stayed steady,it never got that low i checked the oil every day,when i got this car i change the plugs first and everything looked ok,then after the problem the 1-2-3 looked good and the 4 oil fouled( the firing order is 4-1-2-3),the last thing is yes i have but i dont know how to do it? sierrap615 07-24-2004, 03:35 AM to be completely honist, i don't remember exactly how. i've only done one a year ago. but as i recall you put the cylinder at TDC compression, take the spark plug out and put in some type of "adaptor" hooked up to a hand pump. you fill the cylinder up with air, and see how long it leaks down. but the part of it i'm interested in is that sometimes you can hear where the air is leaking out. since you said the vacuum gauge was steady that says intake valves are ok and leads to the head gasket, exhaust valve, or rings being bad. if it was the head gasket, you would most likey be looseing coolent too. i doubt thats it. if it the rings it goes back to the blowby, i forgot to say earlier another sign of blow by is the dipstick will pop-up a little after about 5 or 10 minutes of driving. the saturn rings are real brittle. if the MMO did nothing, they may just be so bad they need replaced. last is the exhaust valve not closing. this may be a burn valve, but the way you described the cylinder head, i think there is your problem, hard to say where. i have a feeling that with 200k that cylinder head is on its way out, its just one valve is a little more worn then the rest. was there any patten of witch rockers where loose? maybe less on the timing chain side and more on the transmission side? adragon202 07-24-2004, 08:39 AM there was no pattern to the loose valves that i remember but i think im going to look at them again.my guess is the ring or valves.im going to start looking for a used head.any ideas?as i said before im dont have much money. sierrap615 07-24-2004, 05:09 PM the 95s have unique cylinder heads, no other year will fit sierrap615 07-24-2004, 05:15 PM also, something i was just reminded of on the sc forum, on some of the SOHC, the intake gasket can get sucked in to the runners. i'm still sticking with the valves or rings, but its just something to test. i would do the leak down test before buying a new head adragon202 07-25-2004, 08:01 AM ok i'll try the leak down test. as you said i'm not sure how to do it but i'll try.the thing i forgot to say is also when i put in a new therm the car is running better but not perfit. sierrap615 07-25-2004, 05:30 PM did you also put in a new ECT? adragon202 07-25-2004, 10:42 PM I haven't done it yet because of lack of money but when I put a new thermastat in it ran a little better. adragon202 07-26-2004, 03:28 PM I have one other thing I thought of.If the ECT is out wouldn't a code bt on?I do get payed this friday so thats when i'll get the ECT. sierrap615 07-27-2004, 12:00 AM no code, the old ones crack and just read low, be sure to get the new "all-brass" design straght from the dealer adragon202 07-27-2004, 12:19 AM ok i think i'll try that next within 1 day adragon202 07-28-2004, 11:29 AM is there any way to change the idle on the motor?Because I change the hose between the intake and the pcv when the car was running and the motor went into high idle and the car ran better.The ect from starun was the wrong conector so im going to return it and try to get a new one from them. sierrap615 07-28-2004, 11:50 PM is there any way to change the idle on the motor?Because I change the hose between the intake and the pcv when the car was running and the motor went into high idle and the car ran better. lets do that as a last resort. change the ECT first adragon202 07-30-2004, 08:24 PM well i tryed the ect and it didn't do a thing.so by you i need a new heads.fun fun fun.unless you can think of something eles. sierrap615 07-31-2004, 06:13 PM you really shouldn't do this but... take off the air intake duct, near the spring on the throdlle body there is a screw covered by a little rubber stub. that is the idle adjusting srcew. adragon202 08-03-2004, 05:38 PM thanks for your help and im going to try a used head. Automotive Network, Inc., Copyright ©2012
