Re: vacation
Update:
Pete's Auto Sales in Nashua, NH, got the proper parts. It was very easy to install the 2 new stantions. I was able to haul the soft luggage carrier from NH to FL without trouble, though I rarely broke 80 mph this time around. I think the old ones were brittle from the FL heat.
I had to replace the rear pads in CT. I used the OE ceramic pads by Reybestos. Only one caliper bolt was corroded. For the $56 they give you new shims and some caliper bolt lube. The el cheapo pads I replaced only lasted about 30K.
My nephew broke the back passenger regulator by pushing the window down (wanted to wring his neck). $120 at the dealer in Ft. Myers for a new one. I'll pick it up and install it tomorrow.
Burned nearly no oil on the return trip. Added only half a quart over the 3923 miles traveled. I'll treat her to an oil change tomorrow.
