17 inch fit...
LeatherChick
07-10-2004, 04:30 AM
heys,
I was just pondering aftermarket rims for a 2003+ SXT...
will 17x7.5 fit well?
I'd also like to get slightly oversized tires to increase the rolling diameter a bit, say 215/50R17's rather than the stock 195/60R15's.
I plan to up the power output, and the 1st gear is fairly low already on the manual, so i wanted the bit of overdrive the bigger tires would give.
Also it would raise the car slightly, so when i lower the suspension it'll go over speed bumps.
... but will that work? :screwy:
or will i rip out my wheel well the first time i hit a pot hole or turn hard?
thanks for any input,
Kath
Pedros91
07-10-2004, 10:23 AM
u mite want to try a 215/45/17 tire. and it also depends on how much you lower it and how u lower it
LeatherChick
07-10-2004, 03:32 PM
well, as snifty as coilovers are... I was just going to cut about 1" out of the springs. (maybe cut 1.5" out in back, level it out a bit)
With the oversized tires that would be only a 0.5" drop in ground clearance. (or i might just cut a half inch out in front and an inch in back for pretty much stock ground clearance)
they already handle pretty well, between new wheels, better rated tires, and the moderate lowering, it should handle really nice :)
if there's room for it all to be done. :screwy:
Kath
Y2kNeon
07-10-2004, 06:22 PM
For what it will cost you to cut the springs and re-align the car, you might as well go with aftermarket springs. It'll cost about the same anyways, and you'll have a better ride. The Eibach Pro Kit gives ya a 1.5" drop and is around 150-200 bucks. Plus the stiffer springs will give you a sportier ride. That's what I would do anyways :naughty:
Pedros91
07-10-2004, 06:46 PM
yes get the pro kit if you cut the springs you will sacrefice the ride of your car and might just rub in the corners and bumps
LeatherChick
07-11-2004, 02:32 PM
kewl, thanx for the tip guys :)
anyone out there have 17x7.5 wheels on their 03+ who could eyeball the spare room?
(SSR Competitions) ooo, pretty :D
http://www.tirerack.com/images/wheels/ssr/swap/ssr_comp_sil_ci3_l.jpg
Kath
nealuss
07-11-2004, 04:15 PM
I have a 2000 neon with 17x7.5 ICW racing 786h's and 215/40r/17 tires along with eibach prokit springs, they fit extremely well and it handles like you wouldnt believe. You probably know this by now but you are gonna feel every imperfection in the pavement. but like i said it handles like a dream and the looks you will get from people makes it all worth 1300 to 1500 bucks
nealuss
07-11-2004, 04:27 PM
oh yeah; you dont want to get your tires profile too big because it'll ruin the look of having oversized rims. all people will see is the big black doughnut on you rims
Dropped2KNeon
07-12-2004, 12:35 PM
I put some 17" X 7.5"ADR rims with 215/40R/17 Nankens and some Eibach Pro kit 1.5" lowering springs. The car handles great and not to mention looks fabulous. by the way mines is a year 2000.
