19mm Main Hub Bolt
DevoutWankelist
07-08-2004, 02:33 PM
Is 110 psi on an impact wrench not enough to take this off?
ShortyDTP
07-08-2004, 02:42 PM
try with an impact gun , still going to take some time.
DevoutWankelist
07-08-2004, 03:15 PM
That is what I am using and it wont come off, will hitting it repeatedly make a difference. If it doesn't come off in the first 30 seconds of trigger pulling, do I just need more pressure?
D3rELiC
07-08-2004, 04:35 PM
hit it repetitively, try to move the nut a bit forward too, but not too much, just to give it some hits.
screw, unscrew, screw then unscrew until it comes off
thats my technic
DevoutWankelist
07-09-2004, 03:16 PM
It is not cooperating, I just keep hitting it and it just keeps not caring. I just bought the air compressor, would more psi make a difference? :banghead:
DevoutWankelist
07-09-2004, 03:55 PM
It is now starting to beat the edge of the bolt off, any suggestions?
ShortyDTP
07-09-2004, 04:45 PM
how much tq does the gun has? because is the gun is does not have enough torque then more psi is not doing nothing.
ShortyDTP
07-09-2004, 04:47 PM
P.S Because I needed a 300lb tq to take that mofo.
DevoutWankelist
07-09-2004, 05:37 PM
*checking
DevoutWankelist
07-11-2004, 06:57 PM
It's off now, I bought a 400lb max wrench and that worked it off!
ShortyDTP
07-11-2004, 08:38 PM
I told you!! I guess is time to dig in. keep us uptade and pic if you can! :)
