Twin overhead Cam motor
Adri fs23
01-28-2002, 03:39 PM
[SIZE=1][FONT=arial][COLOR=deeppink]
:help: Does anyone know anything about the twin overhead cam motor? I just recently bought a 1995 SL2 and there is a compression problem and I do not know anything about it, and need some advice on how to fix it without taking it to a mechanic.:rolleyes:
anna'safagweed
01-29-2002, 11:19 PM
[COLOR=blue][FONT=arial][SIZE=3][I]:flipa: hey! i'm sooo sorry to hear about your problems! sounds like you got yourself into a jam! they call that a lemon... well, i don't have any advice for the twin cam motor... it's not my specialty... :smoka: good luck with your car, have a good life, and good luck in whatever you do... you are a nice person... :confused: keep god in your heart :o and a smile on your face :D and you'll go far...
Tireburner
01-30-2002, 09:31 AM
Which cylinder(s)?
UncleMeat777
05-30-2002, 06:15 PM
Easiest fix to a compression problem is new spark plugs... if you already tried that, then you might be in trouble.
There are a few bright people over at xtremesaturn.com forum, maybe they can help.
bman37
01-01-2004, 03:49 AM
sounds like the same thing im going through
its in the head bad valves I have a 93 sl2
130.000 on it i found and replaced weak valve springs
and worn cup adjusters this did the trick
its a little work but its worth it
VS1400
01-17-2004, 10:14 PM
What do spark plugs have to do with compression?
To the original poster:
How do you know you have a compression problem? What are the cars symptoms?
More info please.
sierrap615
02-06-2004, 04:08 PM
don't rule out a blown head gasket
