recommended lift kits
mountaindew
07-07-2004, 03:13 PM
What would you guys suggest for a lift kit for a 3-4" lift on an '84?
bplummer
07-09-2004, 01:13 PM
if you're looking for a cheap lift, i went with a 3" rough country. it comes with shocks and ends up comiing to around $260 after shipping. it was easy to intall and has held up good.
gtmud
07-09-2004, 01:24 PM
3" for $260? What all came in that kit. I always thought that 3" or more you would need to either drop the T-case or do the slip-jiont eliminator w/ driveshaft. However, Mountiandew, I would recommend you go for the 4" if you can afford it. I will warn you, the kit will practically replace everything under your chassis. You will have to go to a slip-yoke eliminator w/ new driveshaft though. ($1000.00) The 3" lift you should be able to get away with running 31's. Makesure you replace ALL of your brake lines, stock are too short. Good luck
bplummer
07-14-2004, 12:12 PM
my lift came with front coils, rear add-a-leafs, shocks, and hardware to intall. i had no problems with the t-case until i put a big dent in my crossmember which pushed the t-case even higher up so i made a spacer out of 1" square stock to go in between my crossmember and my frame which solved that problem. it's not completely necessary, but i lengthened my sway bar connects by welding in a piece of metal the same diameter. you can buy longer ones, but they cost alot and you can get away with running stock ones, theres just a little more travel with longer ones. my stock rear leafsprings didn't have a lot of life left to them, so the add-a-leaf didn't quite bring up the rear a whole three inches so i put in a lift shackle that lifted the rear another inch. they're easy to install and only cost about $75. if your leaf springs are healthy, you probably won't need them. if you don't have a lot of $ like me, i'd recommend the rough country lift. it rides better on the road then mine did stock and it will clear 31's no problem.
MagicRat
07-18-2004, 09:41 AM
A slip-yoke eliminator is not necessary on an '84. They all came with a 2 pc slip joint driveshaft (one of Jeep's better ideas, they cheaped out in later years when they went to a slip yoke.)
Silver_XJ
07-20-2004, 12:54 PM
Mountindew : I've installed the Rubicon Express Extremeflex 4" on my last cherokee, ride is a bit on the rough side but the articulation is basically unmatched on the cherokee. Cant remember what I ended up paying for it... was about 3 years ago...
The other lift I've used in the past was Old Man Emu , ride quality is better than factory. articulation is excellent too.. but its only 2.5"
Currently I am looking into the Skyjacker 4" for my latest cherokee (yeah the 88. I've owned 2 x 87's and now an 88).
