Clutch problems on P reg fiestaElgeordo 07-07-2004, 07:55 AM The other day whilst driving, everytime i dipped the clutch the engine revved as if i was pressing the accelerator then died as if after one rev this lasted for about 15 - 20 minutes while i was driving but did not start unitl halfway thru my journey!!! Anyway next time i got in the car it was fine!!! Is this anything serious?? Is it a easily fixable problem? Worst comes to worst i still got 2 months warranty on engine and gear parts!!! HELP ME!! mechy1barry 07-07-2004, 02:56 PM if fitted could well be the speed sensor -or idle control valve. Elgeordo 07-07-2004, 02:58 PM if fitted could well be the speed sensor -or idle control valve. ITs just a basic Fiesta 1.3 LX aint fitted anything more than standard!! mechy1barry 07-07-2004, 03:08 PM if you take time to look you could find on the speedo drive(gearbox end)2 wires coming from drive,follow these to the bulkhead connection,and next time it happens-disconnect it.may cure your prob.also check all connections at throttle body.this is a problem with this model as per ford motor comp. Automotive Network, Inc., Copyright ©2012
