86 GL 4drZCrazyman 07-06-2004, 10:01 PM i'm getting code 22 and code 24 how do i get rid of these codes??? Calebz 07-15-2004, 01:35 AM Is the car carb'd or does it have SPFI?.. Or is it possibly MPFI turbo(like mine :) ) 87 is supposedly the first 'official ' year for the SPFI cars, but I have seen that subaru sneaked a few in in 86 as well Whichever it is, to get rid of the codes, you must fix whatever is causing them. Here is some readin for you There are self diagnostic connectors on all models which, when connected together with the key in the ON position (engine off) flash diagnostic codes through the LED light on the Oxygen Monitor on the ECU. The connectors are under the steering wheel, to the left of the Oxygen Monitor on most models. On Carbureted and Single-Point Fuel Injected Models, the test connectors are located on the engine side of the firewall, on the driver's side. There are four test modes. With NEITHER test connector connected, and the key in the ON (engine off) position, the light will display codes that relate to starting and driving. With ONLY the "Read Memory" connector connected, historic codes will be displayed. With ONLY the "Test Mode" connector connected, a dealership technician can perform dynamic tests. The last mode is for clearing codes (see below). The codes are displayed as pulses of the LED mounted on the module. The long pulses (1.2 Seconds) indicate tens and the short pulses (.2 seconds) indicate ones. Pulses are separated by .3-Second pauses, and multiple codes are separated by 1.8-Second pauses. (See Example Below) The codes can be viewed on either the Oxygen Sensor Monitor or the Malfunction Indicator Lamp (Check Engine Light) on the dash, depending on the year and type of fuel system your car has --- CLEARING CODES --- Codes will clear only when the faulty system or circuit is repaired. After making the repairs, codes can be cleared by connecting TWO pairs of connectors, the "Self-Diagnostic" connectors, and the "Read Memory" connectors that are usually located right next to the diagnostic connectors. To begin, start with a warmed up engine, turn the engine off, connect both pairs of connectors, then start the engine. This should clear the codes. If this fails to clear the codes, consult an Authorized Subaru Technician -- 1984 Through 1988 Carbureted Models -- CODE PROBABLE CAUSE 11 Ignition Pulse System 22 Vehicle Speed Sensor (VSS) or Circuit 23 Oxygen Sensor 24 Coolant Temperature Sensor or Circuit 25 Coolant Temperature Sensor (1984 Models) 25 Manifold Vacuum Sensor or Circuit (1985-1988 Models) 32 Duty Solenoid Valve or Circuit 33 Main System in Feedback 34 Back Up System 42 Clutch Switch or Circuit 52 Solenoid Valve Control System 53 Fuel Pump or Circuit 54 Choke Control System 55 Upshift Control 62 EGR Solenoid Valve Control 63 Canister Solenoid Valve or Circuit 64 Vacuum Line Control Valve or Circuit 65 Float Chamber Vent COntrol Valve or Circuit 71 Ignition Pulse System 73 Ignition Pulse System 74 Ignition Pulse System -- For 1984 through 1986 Fuel Injected Models -- CODE PROBABLE CAUSE 11 Ignition Pulse 12 Starter Switch Off 13 Starter Switch On 14 Airflow Meter or Circuit 15 Atmospheric Pressure Switch - Fixed Value 16 Crank Angle Sensor or Circuit 17 Starter Switch or Circuit 21 Seized Air Flow Meter Flap 22 Pressure or Vacuum Switches - Fixed Value 23 Idle Switch - Fixed Value 24 Wide Open Throttle Switch - Fixed Value 25 Throttle Sensor Idle Switch or Circuit 31 Speed Sensor or Circuit 32 Oxygen Sensor or Circuit 33 Coolant Sensor or Circuit 34 Abnormal Aspirated Air Thermosensor (In Airflow Meter) 35 Air Flow Meter or EGR Solenoid Switch or Circuit 41 Atmosphere Pressure Sensor or Circuit 42 Fuel Injector - Fixed Value 43,55 KDLH Control System 46 Neutral or Parking Switch or Circuit 47 Fuel Injector 53 Fuel Pump or Circuit 57 Canister Control System 58 Air Control System 62 EGR Control System 88 TBI Control Unit Automotive Network, Inc., Copyright ©2012
