93 Es300 Rough Gear Shift When Cold, loss of power, accelerationjksc 07-06-2004, 05:42 PM Hello gurus, I have a 93 es300. When I start the car in the morning or after 5-6 hours of rest, the car gives a jerk when shifting from first to the second(could be 2nd to 3rd too...). The problem is less felt if I let the car get heated up for about 5 minutes and start driving. It gets better as the car gets heated up. I feel very slight jerks for shifting of other gears too. My car has 120K miles on it and has new timing belt. I have recently done transmission service on it, but no use. I have also taken it for a trasmission check and they reported no problem in transmission. I have observed considerable loss of power and acceleration from when I got the car around 60K miles. One more observation is that the problem got aggravated after changing the timing belt. I can't seem to find the source of the problem and am worried that I might be damaging something internally by continuing driving without fixing Please help.... ishop4less 07-06-2004, 10:15 PM check if the timing is correct, car will run really bad if the timing is not correct. jksc 07-07-2004, 05:04 PM Thanks for you reply. I'll try that. But does this explain loss of acceleration. ishop4less 07-07-2004, 09:40 PM If the the timing is not correct you will feel a lot loss of acceleration for sure. Automotive Network, Inc., Copyright ©2012
