Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 07-05-2004, 02:06 AM   #1
Josterhout
Josterhout Normal reputation
always power to radio
Hello:
I have a 1999 Tahoe and I have a prob with the radio. There is always power to the radio even when the Ignition Switch is off. I thought maybe the ignition switch was bad, but no other accessories are on when the switch is off, just the radio.
Has anyone else had this prob? if so how did they fix it?
Thanks
Jeff
Josterhout is offline   Reply With Quote
Old 07-05-2004, 08:45 PM   #2
JD68
JD68 Normal reputation
is this a stock radio or aftermarket? if its aftermarket then check you yellow memory wire and red acc/start wire to see its properly wired. if its stock ill check some info and diag it with you. if your handy with a multimeter you can check the seperate leads and also fuses to see where the power is coming to the radio from.
gl
jd
JD68 is offline   Reply With Quote
Old 07-05-2004, 09:28 PM   #3
Josterhout
Re: always power to radio
My radio is stock.
This problem just started yesturday. Now today everything seems to be working fine. The radio now shuts off when the key is off.
I hate electrical gremlins!
Jeff
Bookmarks
Google
Web AF
