Remote Keyless Entry system ???joneswoods1 07-03-2004, 06:52 PM I bought a keyless entry remote on ebay for my car. 1999 toyota 4 runner limited. just bought this car and didn't come with one the guy told me he lost it. the guy i bought the remote from on ebay sent programmikng instructions but the method he sent did not work. all the steps were follwed until the last step it asked to press the lock and unlock button with the door open and that the doors should cycle and that worked but when i get out and close the door i try to lock the doors with the remote and nothing happens has this happened to anyone else or is there other methods i can try for this model year 4 runner. any help is appreciatted. Thank You , joneswoods1 If you like you can e-mail me instructions at joneswoods1@yahoo.com Brian R. 07-03-2004, 07:36 PM joneswoods1 07-04-2004, 01:15 AM GOT IT WORKING USE THIS WORKS PERFECTLY Thanks roadrashjohnny!!! I have a 1999 4Runner and I followed the directions above (which I've copied below) with one exception. In step 8 -- I held the lock button instead of the unlock button in order for the directions to work. Step 1 - open drivers side door and get in your vehicle. Step 2 - put key completely into ignition,then pull out. Step 3- with door open, lock and unlock 5 times on door console (ten clicks total). Step 4 - close door then open door. Step 5 - lock and unlock 5 times on door console (ten clicks total). Step 6 - put key completely into ignition then turn to the on position then pull key out (you will now hear the door locks lock then unlock a couple of times) Step 7 - now quickly press the lock and unlock buttons at the same time only for about a second. Step 8 - then quickly press the lock button for just a second. Step 9 - exit car and close the door After you do this you should hear a beep then your lights will flash. This will indicate that your remote is programmed to your vehicle. Automotive Network, Inc., Copyright ©2012
