Jeep Cherokee Limited 1999shirleycll 07-02-2004, 07:37 PM Recently had a serpenpine belt installed on my Jeep. If the Air it running when I first start it its really loud so of course I turn air off or down. This only happens when I first start up the Jeep. Its been tighten and it well be ok for awhile and then it happens again. What needs to be done anyone have any ideas or solution? gtmud 07-07-2004, 03:23 PM I had this problem on mine, there is a certian tension that the belt is to be at, to much and it will cause BAD things to happen. I have no idea what the tension is, but I slowly tightened my belt till it went away. shirleycll 07-07-2004, 07:18 PM Thanks! I guess we well try that. Its just so embarrassing to me. I had this problem on mine, there is a certian tension that the belt is to be at, to much and it will cause BAD things to happen. I have no idea what the tension is, but I slowly tightened my belt till it went away. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
