Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer
Old 07-02-2004, 10:16 AM   #1
vballfun
vballfun Normal reputation
1995 Blazer computer codes...
I've got a 1995 blazer 4.3l.. my ses light is on.. and I want to know what the computer thinks.. (it's running rough and bucking while in gear and stopped at stoplights.) and fuel consumption is way up.. (usually get 300 m/tank last fill up this past time only got 200 m/tank)
so.. I stopped by Autozone other night to get codes read.. unfortunately I timed it just right for a mini monsoon to pour on me and the autozone employee didn't see the need to get drenched for my codes... And.. he said that they can only read codes for OBD II capable vehicles which are 96 and up..
Does that mean I've got to do the shorting 2 pins trick to get the check engine light to flash at me? Anyone have experience with the 95 blazer and how to get the comp codes?
Thanks,
Tim
vballfun is offline   Reply With Quote
Old 07-02-2004, 01:16 PM   #2
vballfun
Never mind.. I stopped by Autozone during lunch.. guy said same thing about 96.. yet we went out and tried it anyway.. and viola.. even tho it's a 95 still was able to get the codes out of it..
yuck...
p0134 - O2 sensor bank 1 sensor 1,
p0172 - Too Rich, bank 1,
p0300 - Random Misfires..
p0401 - EGR Flow Insufficient
p1406 - "Aux Emission Controls"
Have a happy 4th,
Tim
Old 07-02-2004, 07:40 PM   #3
JS567
JS567 Normal reputation
Re: 1995 Blazer computer codes...
Have the fuel injector checked. Its a common problem on these vehicles 4.3l vortec engines.
JS567 is offline   Reply With Quote
Old 07-03-2004, 10:19 PM   #4
vballfun
Well.. took the EGR valve off today while replaceing my thermostat (seperate issue)
it was definitely sticking.. cleaned it up and put it back on.. so (for now) 3 of the codes are gone.. the O2 sensor.. the EGR flow restricted.. and the Aux Emissions one.. however I've still got:
Gonna try some seafoam I just got.. to see if that cleans up some.
Old 07-04-2004, 04:22 PM   #5
rlith
rlith's Avatar
rlith Normal reputation
Send a message via AIM to rlith Send a message via MSN to rlith
95's have ODBII as well as ODBI.5... If your ECM is under the hood, you have ODBII, if it's under the dash it's ODBI.5...ODBII has side post mount distributor, ODBI.5 has top post... You have ODBII...
That said, Your injector is leaking... Pull your upper plenum and look for signs of washing (where one side is cleaner than the other) If the passenger side is washed, you have a bad CPI, if the drivers side is washed, you have a leaking nut kit... If you do replace your nut kit, replace your nut kit as a matter of course...
Sicne you've been running so rich, you should also replace your plugs/wires/cap/rotor...
Your 02 sensors should be replaced every 65-75k...This is critical for running properly (not rich) and proper fuel miledge...
rlith is offline   Reply With Quote
Old 07-05-2004, 01:08 AM   #6
tomminajar
tomminajar's Avatar
tomminajar Normal reputation
Bank 1 is the left side (Drivers) no-? changing your oil too- It's filled with gas , GREAT for bearings -Shoundn't need any motor flush now...
tomminajar is offline   Reply With Quote
Old 07-05-2004, 05:20 PM   #7
JS567
what is seafoam and what does it do??
Old 07-05-2004, 05:26 PM   #8
rlith
rlith's Avatar
It breaks down and cleans out carbon... Available at NAPA or Advance autoparts
Old 07-05-2004, 09:28 PM   #9
JS567
Just pour it in the gas tank?
Old 07-06-2004, 06:29 AM   #10
rlith
rlith's Avatar
No, with the car running, pour 1/3rd in the brake booster line to flow into the intake... shut the car off for one hour, 1/3rd into the crank case oil (do oil change after 500 miles) and the remaining 3rd in the gas tank... After the hour is up, drive normally (no revving the engine) for about 5 miles... You will smoke a lot, but that's fine...
Old 07-06-2004, 06:30 AM   #11
rlith
rlith's Avatar
Also your 02 sensors still need replaced.
Old 07-06-2004, 09:39 AM   #12
JS567
Is The Brake Booster Line The 1/2 Inch Rubber Hose From The Master Cylinder To The Rear Of The Upper Plenum
Old 07-06-2004, 10:13 AM   #13
rlith
rlith's Avatar
Yep, pull it from the booster side...(lol, don't wanna dump it into the brake booster)
Old 07-15-2004, 01:35 PM   #14
vballfun
Re: Re: 1995 Blazer computer codes...
Originally Posted by rlith
... stuff deleted ...
rlith,
Just wanted to say thanks for the online diagnosis of the fuel injector problems. you were spot on. (see this thread )
Just had two more question.. about the O2 sensor(s). I know of the one under the car right behind where the 2 exhaust pipes meet... is there another one? and if so where?
Thanks,
Tim
Bookmarks
Google
Web AF
