"intermittent" brake lightINMY01TA 07-01-2004, 07:55 PM My gf has a 99 blazer. %99.9 of the time her left brake light doesn't work. Once in a while it does. However, The left brake light works %100 of the time if the right turn signal is on. If the left turn signal is on it will also flash as it should. Any ideas? FCFFUZZYFACE 07-01-2004, 10:51 PM sounds like the turn signal switch is faulty, this is a modular unit with multiple switches inside, this is a common problem FCFFUZZYFACE INMY01TA 07-02-2004, 12:31 AM Would this be the same thing as the "flasher module"? Some one else already said try that. Just wanted another opinion. Is it below the glove box? Thanx. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
