Black tail pipe and bad gas mileage 87 4runnerretrobeast 07-01-2004, 12:48 AM Hey I have a 87 4 runner with a 4 cyl in it. Seems to be getting bad gas mileage and the tail pipe is black. Smelling unburned gas too. Do I need to advance the timing more. I just don't want to have the engine idling too high. Thanks Brian R. 07-01-2004, 11:32 AM Check your computer for error codes. Puffnstuff 07-04-2004, 11:47 AM Check your catalytic converter and make sure that it isn't breaking down. It happened to my 87 and it caused a performance drop. Have you noticed any flat spots or stumbling in the rpm band when accelerating? There are only 4 bolts holding the cat on and be careful when you do loosen it. If the material has broken down then you'll get coated with a powdery substance when it comes loose. retrobeast 07-04-2004, 11:55 AM Thanks for the suggestion. I will check out the cat converter since timing adjustments are not doing much. I do get a gasoline smell though like it is burning way too rich. How do you like the Kia? Automotive Network, Inc., Copyright ©2012
