Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 06-30-2004, 01:25 PM   #1
65 corvair
65 corvair Normal reputation
corvair valve seals
has anyone changed the valve seals on a corvair? What is the difficulty level? I have some white/blue smoke at startup and when accelerated. My guess is the valve seals. I am not a mechanic but if i have a book and some directions i should be able to figure it out, I know if I take it in it will cost an arm and a leg. Any advice is greatly appreciated.
65 corvair is offline   Reply With Quote
Old 07-01-2004, 12:44 PM   #2
formulaross
formulaross Normal reputation
Re: corvair valve seals
If you're not mechanically inclined, I wouldn't suggest trying to do this. It's a LOT more involved than just pulling a cover and replacing a gasket. There are basically 2 ways to change valve seals. One way is to pull the cylinder heads and disassemble the valve hardware on a workbench and change the seals. The other way is on the car and involves pressurizing the cylinder with an air compressor fitting via the spark plug hole, disassemble the valve spring keepers and valve springs and replace the seals and reassemble.
formulaross is offline   Reply With Quote
Bookmarks
Google
Web AF
