larger tires for stock 2003 4-runner?cinndieh 06-29-2004, 11:52 PM Can I put BF Goodrich All-Terrain TKO tires 265x70xR17 on a stock 2003 4-runner. I don't like the Grandtrek tires and want an aggressive AT tire. What size tire would fit without rubbing or lifting? trdspec2 07-04-2004, 01:26 AM 275/60-17 285/60-17 These are the size options avaliable for your truck! The tires you are looking at will affect your speedo and your mph will be off by like 3 to 5mph! My suggestion to you is to go with the 285/60-17. Bf goodrich is a goodchoice, so is the michlien LTX M/S. :twak: Florex 07-05-2004, 02:11 PM Mine is an 04 2WD w/ the standard 265/65R17... i took it to a local firestone shop and they told me i coudn't go any bigger with the tires but i can go wider. Is this true? Is it becuase i have a 2WD? I want some bigger more aggressive tires and I see other runners with them around town, but now my local shop is telling me no? what's the deal? cinndieh 07-11-2004, 10:13 PM I am going to try the 265x70xR17 BF Goodrich All Terrain TAKO. I will let you know if they fit. I don't care if the speedo is off by a bit. I think it is worth the change for better traction. Toyota sure screwed us on this one. Hopefully will have installed this week. I would think the 265x60xR17 would cause speedo changes also. cinndieh 08-01-2004, 05:30 PM I went ahead and put the larger tires on and they fit fine. Kind of close but work ok. Bridestone 265x70xR17 TAKO are great tires. Automotive Network, Inc., Copyright ©2012
