Fuel Pump ? - CherokeeAndyLees 06-29-2004, 08:16 PM My Cherokee is cutting out in a totally random pattern. Sometimes I can re-start it straight away, soemtimes I have to wait anything up to 30 minutes. I have noticed, on quiet days, that a noise from the rear, quite like the fuel pump priming, immediately preceeds the ability to re-start. If this is the fuel pump, can anyone tell me what is likely to "tell" the fuel pump to stop/start pumping? Thanks. gtmud 06-30-2004, 07:34 AM Not quite sure were it is located but I would look for the relay that controls it. Go to autozone .com, and follow the prompts. That should help you a little. good luck. Also if you are stating to here the pump, good chance that it is starting to wear-out. The pump for my 00 XJ is about 200.00. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
