turbo psi
PowerCrazy
06-28-2004, 10:38 PM
just a quick question on a '94 MR2 turbo with stock internals, what's the highest psi you can somewhat safely run? and how high can you go with upgraded internals?
JekylandHyde
06-29-2004, 05:40 AM
If you are using the OEM turbo (CT26) do not exceed 15 psi.
However, with proper enginemanagement, proper intercooling, proper fuel and an upgraded turbo .... .the sky is the limit.
I am running 23 psi on a 197,800 mile 91T engine with a T3T4 turbo.
200SXGTi-R
06-29-2004, 09:26 AM
do you still have stock internals?
JekylandHyde
06-29-2004, 09:53 AM
My engine is 100% original.
Toyota assembled it 14 years ago and the closest anyone has come to touching it is me installing a powder coated valve cover. :)
... head, block, head gasket, pistons, crank, rods, valves, springs, etc .... all original, untouched.
drazhartd
06-30-2004, 02:39 AM
23 psi?
how high can one safely boost with 91 octane?
JekylandHyde
06-30-2004, 06:26 AM
91 octane? ... seeing as the engine the engine requirements are for 93, I would not go over stock boost.
Personally, I wouldn't even run that hard unless I had water injection.
200SXGTi-R
06-30-2004, 08:34 AM
what EMS are you running ..and what sort of A/F ratio do you tune for?
thats an acomplishment for no internal work with that many miles. does is smoke ...even a little?
the cylinder walls and or piston rings gotta start wearing if not yet ...sooon. its inevitable. and if so what will be your replacement?
JekylandHyde
06-30-2004, 08:40 AM
1. Right now I am on the factory ECU tuned with SAFC, VPC and AFPR. A/F was kept under 12:1
2. It does not smoke at all.
3. 15,000 miles of using water injection and I have perfect compression - 176 across the board.
4. 90+ 1/4 mile passes, 20+ dynos pulls, lots of hard street driving and one serious weekend of Hill Climb racing :)
drazhartd
06-30-2004, 02:10 PM
sigh...
91 octane is our premium here in phoenix az.
JekylandHyde
06-30-2004, 02:35 PM
Then ...
http://www.aquamist.co.uk/
