2003 Shift knob removal!TruDestiny 06-27-2004, 02:42 PM Hey guys! I just bought a new shift knob to install into my car, and I've taken the whole console out... I can't seem to get it off, I've twisted it, tried looking for a clip... Nothing, I just can't get it off.... :banghead: It has that lil thing that you pull up to put it in reverse I don't know if that affects anything... Please help me! I'd really appreciate it! Thankies! :smile: SKiUNiT 06-29-2004, 09:38 PM there should be a little kind of like staple looking thing behind the shifter near the radio side that you pry off first. KustmAce 06-29-2004, 09:50 PM blkcavi02 06-29-2004, 09:53 PM if it is the same as the 2002 cavi's then the piece on the top of the shifter that has the numbers on it will pry off, and there is a screw under there. i know when i put on my aftermarket shift knob i had to also remove the piece that you lift up to put it in reverse in order for my shift knob to fit properly. i hope this helps TruDestiny 07-06-2004, 09:32 PM I finally got it off! Thanks to you guys! The advice helped :) :jump3: Automotive Network, Inc., Copyright ©2012
