EGR ValveNY_Vince 06-27-2004, 10:51 AM Does an EGR valve help to reduce CO emissions ? My car failed smog test due to CO gases being slightly above acceptable limit. Could this be corrected by replacing the EGR valve? There are no noted driveability problems. Car has just over 58,000 miles on engine. Last tuneup was done approximately 23,000 miles ago (recommended 60,000 mile intervals). TNX. MagicRat 06-27-2004, 09:01 PM The EGR valve reduces NOx. (Oxides of nitrogen) NY_Vince 06-28-2004, 10:27 AM Thank you for your quick and concise reply. My original post included two questions. Unless I am misinterpreting, your answer to both questions is "No". sierrap615 07-02-2004, 01:36 AM sometimes(namely in saturns) a good cleaning is all you need NY_Vince 07-02-2004, 10:18 AM I have been doing some reading of articles about NOx, EGR valves, Oxygen sensors, and catalytic converters, in an attempt to discover if an EGR replacement is logical for correcting an excessive CO emission. So far, from what I have read, there is no indication or evidence that an excessive CO could be corrected by replacing an EGR valve. However, my recent experience at a dealership's repair shop lead to replacement of the (reported) bad EGR valve. This story does not end here, but I am attempting to prove that excessive CO is not caused by a faulty EGR valve. From what I have read, excessive NOx gases, not CO gases, can be caused by a faulty EGR valve. The NOx and the HC gases were found not to be excessive. What do you experts think? Does an EGR valve function to reduce CO gas emissions? Regards, de ~Vince~ Automotive Network, Inc., Copyright ©2012
