Turn Signals Wont WorkDCHunter 06-26-2004, 10:49 PM Started having problems with turn signals sticking...would either blink very slow or stay solid. Now they won't come on at all. It makes one click sound like it's going to come on, but no signal inside or outside. :mad: Help before I get a ticket!! DCHunter 06-26-2004, 10:50 PM It's a 95 Chevy Blazer 4-door michelq 06-27-2004, 06:55 AM Pull the knee cover,on the right side under a/c panal you will find two flashers swape them around and see if t.s work DCHunter 06-29-2004, 05:43 PM I couldn't get the panel all the way off. The hazard lights work. The turn signals work now, but they are very slow or blink very fast or sometimes they stay on steady. If you jiggle the switch (same one as the windshield wipers are on), they work sometimes. Could it be something in the steering column? chewygoo1 06-30-2004, 11:44 PM Sounds like it is time to replace the multi-function switch. The hazard, turn signal and brake lamps run through it. GM is well aware of this switch having problems and has only recalled the most latest model year Blazers. Visit www.recall-warnings.com to view the recalls. I currently have problems with my switch. The transmission took a dump so I don't have the $285 to buy the replacement multi-function. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
