| Maintenance problems, fixes. |
05-16-2001, 02:30 PM
If your car his hesitating or almost cutting off SE-R.net has a procedure for cleaning the EGR Valve in your car that works great.
http://www.se-r.net/car_info/problem...d%20hesitation
A super novice mechanic like me did it. After I finally found the idle switch I did this and now my car is running great !!!
05-16-2001, 02:34 PM
Diabolical Mod
Congratulations there Slappy!!! You wanna friggin' biscuit?:finger:
j/k
05-16-2001, 03:14 PM
Some of us are proud of our little accomplishments... thank you very much ....
j/k
05-16-2001, 04:45 PM
Diabolical Mod
Originally posted by poppy_morenito
Some of us our proud we know what the engine looks like
 This is fun!
12-13-2001, 12:28 PM
i still dont know how to clean my freakin EGR valve!!!
i dont know where it is?
94 G20t
12-13-2001, 02:17 PM
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
GROUND CONTROL/KYB ADJUSTABLES
17" VOXX MGR 205/40/17
12-13-2001, 03:37 PM
i dont see it!
i have a 94 G
94 G20t
12-14-2001, 06:26 AM
Originally posted by GtRider
i dont see it!
i have a 94 G
Cuz u 94+ has the low-port engine  ...yours is upside down...look underneath and behind.
-Brian Jones
I got a snake man
12-14-2001, 07:42 AM
what are you talking about?
how do you clean it?
94 G20t
12-15-2001, 12:13 AM
GT...it's not that hard. Your intake manifold is covering it, but it's in the same spot as the picture. Since you have a low-port, the manifold overlaps the top of the EGR instead of being exposed like high port. To clean it, take the tube off the top and unbolt the 2 side bolts. If it's clogged it will have carbon build up in it. Clean it out, and replace. You might want to get a new gasket first, they're only a couple bucks. It takes a whole 5 min. to disconnect if you're taking your time.
12-19-2001, 12:09 PM
hey nis.k.a. ,
is that all you have to do to clean the egr??
what to clean it with??
94 G20t
12-19-2001, 06:29 PM
carb cleaner, brake cleaner, and some rags. Just make sure it has evaporated before re-installing. Make sure that it plunges smoothly.
01-02-2002, 11:58 AM
where are the 2 bolts that hold down the egr vavle on a 94G?
94 G20t
01-02-2002, 06:39 PM
The bolts are about one inch down. There's two; one on each side. If you can't plainly see the bolts, you're most likely looking at the AIV valve. You want the EGR which is farthest to the left if looking at the engine.
