Ok here's the scoop. The tires that came with your Runner had 4 tire valves that were registered to the tire pressure warning system ECU in your vehicle. Your spare tire valve is also registered to your ECU. When you switch tires, wheels etc. you need to either swap the valves out of your old rims or take your Runner to the dealer and have them register the new valves to your ECU, which is very time consuming.
The tires need to be taken off the rims, and the ID numbers need to be written down from your new rims. You'd also need to remove the spare and get the number off of that valve as well. If you have a new spare, you'd have to do the same to that. You need to have the ID numbers from the tires that you are no longer using removed from your ECU and the new ID numbers need to be registered. It's a very complicated system.
If you take the Runner somewhere to have the valves switched from your old rims to your new rims (this will avoid having to register all the new numbers) make sure that they install them the exact same way that they were in the old rims. This is VERY important.
