4.3 Stroker Kit???pnoiSR20 06-25-2004, 09:27 PM Their is a 4.3 liter stroker kit out there rite now. I just saw in the July issue of Super Street. If i use the stroker kit in my car, will it help bulletproof the engine if i install a turbo kit??? VQuick 06-26-2004, 07:14 PM AEBS, the company that produces the stroker kit, also has sleeves available. The sleeves will help build up your engine to handle more boost. I'm not sure if they are included with the stroker kit or not. pnoiSR20 06-27-2004, 09:40 PM Yeah i saw the pic and it does look like the sleeves are also included. omega_2099 06-28-2004, 11:36 PM Here is AEBS' website. http://www.aebsracing.com/main.pl The kit contains sleeves that have been tested to withstand up to 55pounds of boost, connecting rods, your choose of different compression pistons Turbo 8.5 : 1 / 100mm, engine size 4231.16cc N/A 11.0 : 1 / 101.5mm, engine size 4269.35cc N/A 11.5 : 1 / 101.5mm, engine size 4269.35cc Includes chrome steel rings, wrist pins and clips also a new custom cut comtec head gasket, and a new forged crank with the bigger stroke. the downside to the kit is you have to send your block to them and they install everything. so that means you have to wait between shipping time and build time.....advantage is that each kit is custom made so you know there is going to be great quality put into this kit.....it would be amazing to get the AEBS stroker kit with the 8.5:1 pistons and run alot of boost from a turbo kit.....you would have an unstoppable Z, if you could get traction..... 2003_350z_Touring 07-04-2004, 02:51 PM the AEBS stroker kit is definately the way to go if you plan on cranking up the boost past 8 or 9 psi...i just wish the kit wasnt so damn expensive pnoiSR20 07-05-2004, 07:34 PM how much does it cost? THT 07-05-2004, 07:38 PM $7,800 or so plus installation. ~THT Automotive Network, Inc., Copyright ©2012
