Shift rod problem?? HELP
corydeeznutz
06-25-2004, 08:45 PM
The car is stuck in 4th gear and the shifter is able to move up and down freely not side to side. Is it solely the shift rod? or could it be something else ???? need advice on what to do and exactly what parts to get
ac427cpe
06-26-2004, 12:35 AM
did the cable come off of the transmission?
corydeeznutz
06-26-2004, 05:10 PM
the car isnt right here right now so I cant really answer your question, but i believe it is. A friend who also owns a MR2 said the same thing happend and he had to replaces the shift rod or cable. Where and how much can i get the part? Is it a hard install?
ac427cpe
06-27-2004, 05:59 PM
if it just came off, put the rear end up, put the cable back on, put a new cotter pin in... and poof! you're done
if the cable broke, it's a bit more involved. you have to take the center plastic stuff off and the shift boot (assembly) off and do a whole new cable.
corydeeznutz
06-27-2004, 08:06 PM
thanks man.. do u think it would be worth it to check at the junkyard to get the cable or should i go to the dealer? how much would it run?
JekylandHyde
06-27-2004, 08:41 PM
I think both shifter cables are a bit over $200 from the dealer.
It is fairly common to brake them over time.
corydeeznutz
06-28-2004, 02:23 PM
yup 227 dollars damn i just got my mr2 2 days ago too .. not cool
ac427cpe
06-28-2004, 09:45 PM
ebay? or a junkyard?
corydeeznutz
06-30-2004, 05:12 PM
Anyone want to tell me how to put this cable in?
corydeeznutz
06-30-2004, 05:39 PM
do you have to get under the car? or can u do it with just the center plastic console thing off?
JekylandHyde
07-01-2004, 08:06 AM
Cotter pins at the shifter and at the tranny.
Pop them off, undo the cable where it comes through the firewall.
If memory serves, one cable is easier to get from the top of the engine and the other is easier from the bottom.
corydeeznutz
07-01-2004, 12:39 PM
yep, pretty easy completed it yesterday and my cars back on the road thanks :)
ac427cpe
07-01-2004, 07:36 PM
yay! congrats :)
