Firewall...GRRR
streetracer1
06-23-2004, 02:40 AM
ok well i was wiring up some stuff today and found that hole in the firewall on passenger side. its liek that huge square grommet and has taht smaller square one inside. i got the smaller one out easily and then i found out that big one is impossible to get out and its huge. i found it when i crawled under my car.. its liek a giant boot and i cannot get it out. how did yall get it out or through it? is there any other hole in the firewall? cause i read on the clubGP modification area that this grommet is so easy to get out. thanks
ryan
streetracer1
06-24-2004, 12:40 AM
bump.... thanks
Ripn12s
06-24-2004, 01:20 AM
There is a smaller gromet on the drivers side, just above the brake pedal.
streetracer1
06-24-2004, 02:10 AM
like wehre the pedal goes through the wall?
Ripn12s
06-24-2004, 09:07 AM
Around that area.
Get a flashlight and crawl up under there. I ran all my wires for the gauges through the driver sde gromet
streetracer1
06-24-2004, 01:17 PM
ok thanks ... yeah im only runnin a small 12 gagues wire so it should work. thanks ripn
streetracer1
06-27-2004, 03:11 PM
um .. could u post a small of this hole in your car.... cause i cant find it in my car... thanks AIM me at FenderStrat814 if u want to send the pic there .. thks man
kilroypr
06-27-2004, 05:07 PM
I passed all the cables and oil line for the oil PSI gages thru that small hole over the break pedal...
Ripn12s
06-27-2004, 05:34 PM
What year car?? We are talking 97+ right??
Take the 2 lower panels off. The one by your feet and the one by your knees. Shouldnt be too hard to see.
streetracer1
06-27-2004, 05:49 PM
ok well i couldnt find it so i made a way through the one on the passanger side.. thanks tho man.
kilroypr
06-27-2004, 05:51 PM
Man, if you take the panel under the steering wheel you would see the hole over the break pedal. Do not have to run all those cables behind the AC
