will a viscous LSD drift well?
winstonusmc
06-22-2004, 10:10 PM
I have caught the Drift Bug and I want to put an LSD in my SR20DET powered 240sx. Viscous seems to be way more affordable than clutch type. Will the viscous LSD drift very well, or shiuld I save my money for the clutch type?
TheLogikal1
06-22-2004, 11:44 PM
it sucks if you want to get to serious drifting.
TheLogikal1
06-22-2004, 11:45 PM
but drifting is about the driver and his/her skill, so don't worry aout it too much. any lsd is better than none.
the clutch type would make it much easier, plus its more dependable
Soyo
06-23-2004, 12:01 AM
yea viscous wouldn't be the best choice, its worth the extra money to get a clutch type LSD because it will last longer, be easier, and more fun
theDRIFTER
06-23-2004, 11:00 AM
What about the PHANTOM GRIP limited slip conversions they sell on NOPI? Sounds cool? Does it work? :uhoh:
SR20DETpower
06-23-2004, 01:58 PM
shit you can get a car all sideways and control a drift with an open differential if you know what your doing(hint hint other then over powering the corner lol)
so a VLSD will work even better then an open to make the rear end slide out easier
a clutch type will last longer and locks up the most. All a LSD really does is make the rear end slide out easier in turns with both tires spinning the same speed and covering different distances from a slide.
a VLSD is ok, it essentially works just as good as a clutch type, just doesn't lock up quite as harshly as a properly adjusted clutch diff for hard lock-up, and it also does not last as long as a clutch diff for drifting, it wears out quick when your burning tires up all the time.
R.W.240
06-23-2004, 04:32 PM
a Phantom Would Suck. all it does is wedge the spider gears into the Housing via A Spring and Two Blocks. Its torque Capacity has to be extremly limited and its Grinding Metal on Metal (granted Clutch types do this but the clutch packs are replaceable and its in a way that was considered when engineered)
theDRIFTER
06-23-2004, 09:20 PM
Do you know someone that had a Phantom? Cuz that seems like a cheaper way to go, but I know you get what you pay for. Just wondering!
theDRIFTER
06-25-2004, 01:04 AM
does anybody have an answer for me yet... has anyone ever had a Phantom, and how was it... I'm only going off of asumptions(mostly true, but still)
R.W.240
06-25-2004, 10:56 AM
I Dont have one... nor will i ever. The FF DSM guys have had mixed results with them (drag) but the AWD guys hate em. either way id put money on that at a drift event it would work about as well as a viscous for one Run before Fn the Diff up.
theDRIFTER
06-25-2004, 01:09 PM
Thanks... that answers that question... just gotta put out the $ for a real LSD.
SR20DETpower
06-25-2004, 04:15 PM
yeah if your going to actually buy a new one, defintely get a good clutch aftermarket diff, NISMO even sells one......
mynismo
06-26-2004, 07:21 PM
phantom's suck.
and you definately need an lsd and some power if you want to drift. you should be running at least in the mid-15 arena and have a fairly good suspension setup (at least strut/spring upgrade). but lsd (any lsd) is definately a must. anything upwards of that is your own preference, and your own wallet :)
