98 JGC 5.2L Water Pump
Fondew
06-22-2004, 08:38 PM
I need to replace the water pump on my 98 grand cherokee. After taking a close look at it I notice that there is a metal tube coming directly out of it that feeds the heater core. There seems to be no fittings on this tube,its just a straight shot into the pump. I looked at a new pump at the parts store and it doesnt come with a tube already in it. before I tear it apart can anyone tell me how does this tube get removed and reinstalled. Is it pressed in or what? I'M BAFFLED!!!
Any info greatly appreciated!!
Rich
nick capage
06-25-2004, 12:36 PM
one bolt holds the tube to the water pump.then just pull it out,at the end of the tube is a o ring. replace it, put black rtv silocone on it and re install
dksob81
09-09-2004, 12:40 AM
that black tube get's mounted to the Drive Accessory Bracket with a bolt, and there is an O-ring atached to the end of it, I think a newO-ring comes with the Gasket for the water pump,, just put the new O-Ring on the tube and put a thin coat of clean engine oil on the O-Ring (it will help the O-ring slide inton the water pump), and push the tube into the water pump do not twist or turn it, u may break the O-Ring which will cause a leak. and make sure u put some RTV (BLUE) or (RED) on the block and the water pump and then put the gasket on and torque to spec (30 ft./lbs)
