Running Board InstallationMekanic 06-22-2004, 03:00 PM My son has a '96 Grand Cherokee and was given a set of Aluminum tubular running boards that will fit this vehicle. Upon looking under the chassis at the frame I did not see any pre-drilled holes for the mounting brackets of the running boards. Would large diameter ( 1/4" to 3/8" )sheet metal screws be sufficient to fasten the brackets to the frame? Or should we try to drill holes in the frame to accommodate long bolts? Thanks for your advice. :smile: chris5.2 06-23-2004, 08:30 AM hi, when i got my gc93 it had on runing boards held in place by big screws ,they use to shake like crasy . i had to have the brackets welded to the frame , i hope this help . chris5.2 Automotive Network, Inc., Copyright ©2012
