How to remove rear light assembly, 2002 Grand Laredo
mccab9582
06-21-2004, 11:24 PM
Does anyone know how to remove the rear light assembly. I removed the two screws beside the tailgate jam but seems there is a ball and socket joint that prevent removal of the assembly. I did not want to just pull it as it may breakt the plastic assembly and in the same moment cost a few hundred $ to replace.
Any suggestions will be appreciated.
sdtejano
07-03-2004, 12:46 AM
I am having the exact same problem. Have you gotten any good answers?
sdtejano
07-18-2004, 02:48 AM
I had the same problem with the tailight. The only 2 visible screws are removed but the light fixture does not come out. What you need to do is twist it slightly either way and pull. It is simply a round ball attached to a small rod that SNUGGLY pops in and out. Once you pull, even though you think it will break, which it won't, it will come off. I just did this today and finally managed to change my brake light.
good luck
