Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Passat > '97+
Old 06-21-2004, 02:40 PM   #1
bstevenso
bstevenso Normal reputation
Question 2002 V6 oil burning
My 2002 Passat (V6) has 32,000 miles and is burning about a quart of oil every 1000 miles. I have had no other engine problems and submit the car to what I would consider normal driving. No leaks or other obvious problems have been found. VW of America is telling me, through my dealer service, that this oil burn rate is "acceptable" and "industry standard," so they won't authorize additional diagnostic or repair. My dealer service is perplexed ("I'm in the industry, and that is NOT standard!") and has asked me to initiate a complaint through central VW customer advocates, which I have done. Does anyone have any relevant thoughts on this and/or how I should proceed? Thanks.
bstevenso is offline   Reply With Quote
Old 06-21-2004, 03:00 PM   #2
Lee420
Lee420 Normal reputation
All I can say is that an engine that burns a quart of oil every 1,000 miles is NOT ACCEPTABLE!! I am shocked that any self respecting technician would say such a thing.
In my opinion either it is running a little bit too hot or you have an undiscovered leak.
I wonder if these jerks at VW would find it "acceptable" if their car burned a damn quart of oil every 1,000 miles??
Lee420 is offline   Reply With Quote
Old 06-21-2004, 08:23 PM   #3
spasticone
spasticone Normal reputation
Re: 2002 V6 oil burning
All I can say... If it was my car... VW would be told it had started burning 2 quarts and I had filled it before I went in. I'm sure you can find a way to make sure it is looked at. Get it before warranty runs out because I'm sure it would be unacceptable after the last day of it runs out.
spasticone is offline   Reply With Quote
Old 07-19-2004, 08:13 PM   #4
usjoi
usjoi Normal reputation
similar story
I bought a 2001.5 (same body/eng as 02) preowned certified from a dealer in the boston area.
It was a leased vehicle, had 31,000 mi and was very clean. Having bought it from a dealer, I assumed everything would be OK.
About 2-3 weeks later I was thinking that I should check the oil on the off chance that the dealer may have left it low. In fact it was. It was clean, but low by about 1 qt. I figured that when they changed the oil they must have not accounted for the filter (or something.....hmmmmm).
Went about my business after that and (blindly) thought I was OK.
Then, about the time that my oil change was due (~5k mi), I was "zipping" through my pkg lot and did a quick left/then/right turn pretty aggressively and my OIL light came on and "STOP Engine !" showed on the digital display. Needless to say I was concerned (and pissed). After the engine cooled off, I checked the dip stick. Not a drip on it ! Down about 1.5 qts ! So in about 5k mi after owning the car I've burned (?) about 2.5 qts. Not quite the pace of 1 qt every 1,000 mi, but enough to be disturbing.
When I took it to my local vw dealer to have the oil changed (after I wimped out, following looking under the car), he casually said that it wasn't uncommon to burn that much.
I used to beat the crap out of my 93 passat vr6 with 170,000 and that didn't burn a drop !
Now, I am running a "scientific" experiment by ranking the position of the oil on the dipstick and monitoring the level every Monday on flat surface with the engine cold.
I will track it and get back !
Please post any info you get after going to Corporate
usjoi is offline   Reply With Quote
Old 09-26-2004, 03:21 AM   #5
warschad
warschad Normal reputation
vw passat 2000 also burning oit
I recently began experiencing the same problem. I had noted that my passat was down about 1 quart after driving 2000 miles. I added oil and checked after about another 500 and the oil was down again. I took mine into the dealer and they had it for 2 days...no results. They could find nothing wrong with it. Dealer claimed that it was within acceptable standards to burn 1/2 to 1 quart after 1000 miles...I'm still searching for an answer on this one.
warschad is offline   Reply With Quote
Old 10-05-2004, 11:02 AM   #6
netlaw
netlaw Normal reputation
2001.5 Passat Burning Oil
My Passat was burning oil and it was found to be a very tiny leak of the cam seals (I think that's what the dealer said) it was covered under the 10y 100K powertrain warranty.) The leak was putting oil on the exhaust manifold and burning away at very high temps. There were no signs of leaks otherwise.
I happened to have the car run out of gas (bad fuel level sender) and when I looked under the hood, I saw a small amount of white smoke coming out. It was this symptom that got the dealer looking for the leak.
Anyway, the leak was fixed and didn't cost me a penny!
netlaw is offline   Reply With Quote
Old 11-03-2004, 11:30 AM   #7
usjoi
Unhappy oil burn update
finally conducted my "scientific experiment and posted a graph in the General Images catagory.
Bottom line for me is ~1 qt every 2000 miles (text on graph says 'every 1K but that was my error). Still not happy.
I will go to the dealer this week for an oil change and complain again, but not sure what else to do.
Any of you have Any luck from corporate ?
Old 11-21-2004, 06:39 PM   #8
JohnV1317
JohnV1317 Normal reputation
I have a similiar problem and my VW dealer has offered no help. They came up with a technical bulletin dated 1992 that says that 0.5 to 0.85 quarts per 1000 miles is within limits. wondering if you have had any luck with VW corporate.
JohnV1317 is offline   Reply With Quote
Old 12-03-2004, 11:14 AM   #9
bryan_johnson
bryan_johnson Normal reputation
Re: Re: 2002 V6 oil burning
My 2000 V6 (33k miles) has always used about a quart every 3000miles. I'm not sure if its from burning or leaking or both. I have a fair bit of leaking around cam seals - not enough to drip on the floor, just enough to get the motor dirty. Do you guys think I have a case for some warranty work?
bryan_johnson is offline   Reply With Quote
Old 10-07-2005, 02:52 PM   #10
gtechtv
gtechtv Normal reputation
2001.5 VW Passat V6 30V consumes oil
I have a better one for you! I have a 2001.5 Passat in wich the VW dealer replaced the engine because around 30K Miles it would burn 1 quart or more of oil for every 1K miles. They replaced the engine becasue they had no clue what was going on and they had waisted about 7 days in troubleshooting. Now I have 57K miles (27K on the new engine) and I am burning oil again!!! Not quite 1 quart per 1K miles but its getting worse!!! VW should be hit by a class action suit!!! With todays gas prices, the last thing I wanna do is add a quart of oil every thousand miles!!! Oh and another thing; once they replaced the engine, I realized that I had lost power with the old engine. I thought it was just me getting used to the cars power. Good Luck to everyone!!!
gtechtv is offline   Reply With Quote
Old 10-07-2005, 10:34 PM   #11
passatGLwgn
passatGLwgn Normal reputation
Re: 2001.5 VW Passat V6 30V consumes oil
Dont bash VW. They are teriffic. 203,000 miles,mine still pulls hard, 34-37 mpg avg, and no rattles, & no problems, and I use MOBIL 1 Synthetic. Mines NEVER DOWN. EVER. Period.
passatGLwgn is offline   Reply With Quote
Old 10-08-2005, 03:58 PM   #12
boschmann
boschmann Normal reputation
The old Passats are completely different cars than the newer ones.
It's like GM's problem with the modular engines ('99-'03) in the trucks & SUV's with their skirtless piston design that ends up with piston slap & oil consumption. At first they said yes it's a problem, until they figured out it was in over 800,000 units. Now they changed the acceptable oil consumption to 3.75 quarts between changes & raised the acceptable engine dB levels. Needless to say they have a class action lawsuit against them.
boschmann is offline   Reply With Quote
Old 10-09-2005, 09:27 PM   #13
Duncan1
Duncan1 Normal reputation
Re: Re: 2001.5 VW Passat V6 30V consumes oil
We've had a 99 Passat and never had problems with it. Sold it with 130k on it and now have a 04 Passat and love it!!
Duncan1 is offline   Reply With Quote
Old 10-11-2005, 10:49 AM   #14
VWingram
VWingram Normal reputation
Re: 2001.5 Passat Burning Oil
What year is yours? I am worried I will "not have an issue" until 100k mileage is up. What did the dealer say was the issue?
VWingram is offline   Reply With Quote
Old 10-11-2005, 02:50 PM   #15
gtechtv
I don't think you are talking about the same car as we are. No passat gets that kind of fuel mileage; not even the turbo...unless you have a diesel which of course is not what we are talking about. We are specificaly talking about the 2.8L V6 30V engine which is an AUDI engine not the famous 2.8L VR6 engine which was designed and built by VW.
Notice how the 2.8L V6 30V engine was quickly replaced by the 3.0L V6 30V engine in the Audi line up!!! Also notice how VW is now using the famous VR6 engines in the 3.2L and 3.6L versions!!!
Bookmarks
Google
Web AF
