1993 GC RPM problemshooter 06-20-2004, 10:51 PM My RPM's keep fluctuating from 2000 to 2500 at highway speeds. It feels like it's dropping down a gear, which would cause the RPM's to raise, then the RMP falls back down, as if the car shifts back into a higher gear. I got a tune up and fluids changed but it didn't solve the problem. Maybe it's the vacums, but I'm not sure. If anyone has any suggestions I would really appreciate it, thanks. driede 06-29-2004, 04:53 PM My RPM's keep fluctuating from 2000 to 2500 at highway speeds. It feels like it's dropping down a gear, which would cause the RPM's to raise, then the RMP falls back down, as if the car shifts back into a higher gear. I got a tune up and fluids changed but it didn't solve the problem. Maybe it's the vacums, but I'm not sure. If anyone has any suggestions I would really appreciate it, thanks. [COLOR=palegreen][FONT=arial black]I :banghead: chris5.2 07-01-2004, 09:06 AM I use to have a similar problem in an older car , check your transmision oil level . shooter 07-01-2004, 11:04 AM I did have the transmission fluid flushed, but I'll take a look at the oil levels, thanks. Automotive Network, Inc., Copyright ©2012
