Transmission problems?
StickyMits
06-20-2004, 06:33 PM
I am having difficulty putting my car into the reverse gear. Its not making any sort of grinding noise like it would be a transmission problem. Has anyone else had this sort of problem with their 95 GST. I am thinking its my shifter bearings, however, my friend said it could be the transmission since the reverse gear is usually the first to go. I am confused? If anyone could help me out that would be great.
joemathews
06-20-2004, 08:44 PM
Hmm I don't know if it is a problem necessarily. I have the same trouble sometimes. It takes a few tries to get the shifter into reverse; like, it doesn't go in all the way, so I have to take the clutch out, then back in and try again. Usually goes in on the second or third try. I'm not sure if this is normal, but at least you aren't the only one with the problem ;)
guitarXgeek
06-20-2004, 09:39 PM
You aren't the only two, I have this problem every now and then as well. Just do what joe matthews suggested, thats what I do too.
98GSX
06-20-2004, 10:37 PM
its called a synchro and you need one
ashah000
06-20-2004, 11:15 PM
I have the same problem on my gs. It seems a lot of people do.. probally just wear.
And reverse does not have a syncro
Shpyder
06-20-2004, 11:23 PM
You know, I just can't understand Mitsu. for their cheap ass trannies. I had a 98 Spyder with a very cranky tranny that would just refuse to shift smoothly, even after clutch changes etc. Sometimes I couldnt get it into first gear on a stop sign! My 97 GST does the same thing. And would you beleive my bro's 96 GST has the same tranny problems. All Eclipses before 99 had a host of unpleasant tranny and crankshaft issues, though they have gotten better over time. Hondas have silky smooth transmissions...too bad Mitsu didn't steal from their parts bin! (Though I am GLAD Honda didnt make the Eclipse...if they had, our 210 stock GS-T's would've been 180 hp @ redline VTec crappers, and the AWD GSX woudlve probably been dumped!)
1stGenRocks
06-20-2004, 11:26 PM
anything will shift smooth if it only has to handle 95 hp lol
JoeWagon
06-21-2004, 01:10 AM
I would have to say that a DSM tranny isn't that bad. You've really got to have something good to handle AWD launches. I haven't heard anything about breaking trannies locally, or really read about any. On the other hand, I know several people that have trouble with WRX trannies, and online they are said to be weak. As for not being smooth, I wish mine were smooth too but I'll put up with it.
I sometimes don't go into 1st or reverse on the first try.
95eclipse-gsx
06-21-2004, 01:16 AM
oh my... i have the same problem too was shitting in my pants thinking that the tranny was gonna go... i have some kind of short shifter and its really hard for me to put it into 1st gear in the ist attempt... and to put it into reverse is a Bit@h :( ... plus whenever i put it into reverse i hear a LOUD CLANK (sound from under my car and the reverse gear doesnt go all the way in... but it still drives normal... can anyone help me??? wat do abt this sound only in the reverse gear :(
Snowbrdr1122
06-21-2004, 09:14 PM
I had the same exact problem with my 96 GST. It only got worse, after some time of ocasionaly not going into reverse or 1st on the 1st attempt, first gear was completely gone, it would go in fine, but then grind and kick out as you let the clutch out. I ended up having the transmission completely rebuilt. I have pictures of all the gears and Syncros that were replaced if anyone is interested
95eclipse-gsx
06-21-2004, 09:39 PM
I'M SCARED :crying:
Shpyder
06-25-2004, 04:40 AM
Snowbrdr1122: Does your car shift better now? Im worried about my tranny too...it doesn't shift smoothly at all...I have to wince and hope that the gear finds itself with every shift! First gear and reverse gear are a pain in the a$$. The gear just doesnt seem steady...it wobbles in its slot, refuses to engage at times, grinds, etc etc. Oh and I have a new clutch. So is it the tranny or just some little parts that need adjusting/teaking or replacing? I know nothing about trannies.
