Could this be a gasket failling?Julioluko 06-20-2004, 06:28 PM All right guys I have this mad ticking comming from my #1 cylinder and I was wondering could (A). This be caused by my exaust gasket failing and I am hearing the valves and pistion louder on that side of the engine? (B) i had something in that same cylinder when i first started it up and what ever it was beat the the hell outa my NGK and got inbeded in my head and i was wondering could this have gotten unlogged and is now sitting in the seat of my exhaust valve causing this loud ticking. (C) I had my valve cover off for a while and the cams and other valves got un oiled and are now ticking (doubtfull but im not ruling out anything yet) I would just appreciate some advice here, thanks. Luke JoeWagon 06-21-2004, 01:06 AM I don't think it would be the exhaust gasket. If it was, you would hear the engine louder too, not just a ticking. It's possible that you have some damage to the valvetrain, maybe something on the valve seat or a chip in the valve, all will require taking it apart to see what it is. Lack of oil would cause a lifter ticking, too. kjewer1 06-21-2004, 02:30 AM Yup, if you know you had foriegn objects in that cylinder, you should tear it down to see what it did. thefro 06-21-2004, 02:56 AM a compression check in that cylinder wouldnt hurt eather, see if it damaged the cylinder walls or valves. kjewer1 06-21-2004, 08:29 AM Good call. Automotive Network, Inc., Copyright ©2012
